With sync cords and radio triggers you should be aware that you'll be limited to manual flash (i.e. full power, half power, quarter...), although that's not a bad thing, and probably what you teacher would rather have you use anyway. You won't have pTTL functionality. The Canon system is a bit more sophisticated so your teacher may not be aware of this limitation, you should probably ask.
There is whats known as a
TTL cord that attaches to the hotshoe at one end and the flash at the other, or Pentax sells a rather confusing and expensive system of cords and hotshoe adapters that accomplishes the same thing. If you need pTTL functionality, this is what you'll need to get.
