09-21-2012, 09:15 PM   #1
Will old Pentax-A 50mm 1:2 fit my K5
Does anyone know if a old 50 mm 1:2 Pentax -A fit my K5. I have been told that it will but as a beginner I'm not sure what I'm doing wrong as it fits ok but juts unable to take a picture. any help would be great.
09-21-2012, 09:26 PM   #2
arnold's Avatar
In order for the K5 to be able to use the auto aperture of the A lens, you need to go into the menu page C4 item 27, and select 2
This allows the camera to read the aperture ring on the A lens IF you select 'A' on the lens.
You can use aperture priority then, or manual. Of course you must focus manually.
09-21-2012, 09:26 PM   #3
If it is on A, but still isn't working, clean the electrical contacts of the lens with some alcohol.
With the lens on A, all metering modes will work, Av, Tv, TAV and even Auto.
09-21-2012, 09:40 PM   #4
Dear Elliott thank you for all your help ,I got it working. Just have to get better using it like they did before automatic. Considering I only paid $15 its great so far.
09-21-2012, 10:13 PM   #5
QuoteOriginally posted by Skipper74 Quote
It should work in A mode too, but it sounds like the lens may be damaged.
camera, dslr, fit, k-5, k-5 ii, k-5 iis, k5, pentax k-5, pentax-a 50mm
Does th Pentax 31 or Sigma 30 fit in my kit. campdog Pentax SLR Lens Discussion 8 10-02-2011 04:43 AM
smc pentax-M will it fit K10D pentaxk10duser Pentax SLR Lens Discussion 4 06-01-2011 10:19 PM
So I need a 47mm lens hood to fit my 50mm lens? lovemehate Troubleshooting and Beginner Help 15 04-18-2011 12:51 AM
would these fit a pentax K... slip Pentax SLR Lens Discussion 3 02-21-2011 07:22 PM
Will this lens fit Pentax K-x newyorker Pentax DSLR Discussion 26 10-04-2010 01:23 PM
All times are GMT -7. The time now is 12:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
