11-09-2012, 02:01 PM - 1 Like   #16
TER-OR's Avatar
If I may be presumptive - all APSC cameras will be tricky to focus manually. The Catch-in-Focus feature makes this much easier, and of course you can add a split-screen focus screen. I did that with my K-10 and it works well. The viewfinder is simply smaller, making manual less easy. you'll find plenty of people here producing stunning results with old manual glass - much of which provides outstanding color response!
If it means anything, I think Pentax takes manual-focus much more seriously than any other brand. Hence, you have shake reduction in-body and support for all K-mount lenses. I'm sure you found this during your own research.
When it was time for me to move into DSLR I went into Pentax for those same reasons, and I had NO legacy with Pentax. My wife has an unworking Minolta X-700 with standard kit lenses and my Father has a manual Minolta (X-7?) with some very nice glass. I wanted the easy manual control with well-placed controls and two wheels.
I got the 18-135 which isn't the old motor system. It's my only motorized lens. I hear Sigma's motor system is quite nice. I did buy a used Sigma 28mm f1.8 Macro, which I really liked when I rented.
You know the advice here can be biased but I find a lot of honest responses too. I'd find it hard to resist the K-5 IIs if it were my decision, as I do a lot of 100mm macro use. I'd also find it difficult to make that decision when compared with gently-used K-5s on the market for half the price....
Oh, as for the freezing issue. I think mine froze 5 times, all in the first few months of ownership. IIRC it is a battery overcharging issue.
10-06-2013, 06:58 AM   #17
I have a new question about the K-5 II. Often in bright sunlight I am unable to see the "shutter speed, f-stop, leveling lines, anti-shake, and ISO speed" indicator in the viewfinder, at the bottom of a horizontal photo.
I have gone through the manual and don't find any references to ways to brighten this viewfinder display. Is there a way to increase the brightness of this data so it can be better seen in bright sunlight?
Thank you!
10-06-2013, 11:10 AM   #18
fs999's Avatar
You can memorize the exposure with the memory lock button and put the hand before the lens...
10-06-2013, 04:16 PM   #19
QuoteOriginally posted by fs999 Quote
Thanks fs999 but what I'm most concerned about is the image leveler which I have activated. For some reason as you get older it's more difficult to get a dead level photo. I need to see this in real time, as I'm taking the photo. Maybe a Pentax techie has an answer. ??? Thanks again.
10-06-2013, 04:40 PM   #20
jatrax's Avatar
QuoteOriginally posted by StrasburgBarry Quote
Not that I'm aware of. I just use the bottom or top of the frame for leveling and correct any slight deviation in PP. It must be really bright where you are at, I've never had a problem seeing the data in viewfinder. LCD is a different story of course. Do you wear glasses? Maybe you are not getting a good fit between your eye and the viewfinder?
10-06-2013, 04:51 PM   #21
Thanks jatrax. Yes, I do wear glasses and that's probably the problem. A rubber eye cup might come in handy. For some reason, using the upper/lower part of the image doesn't seem to work for me. This isn't really a major problem that happens all the time. It isn't that bright here at latitude 42 degrees north. Guess I'll just have to live with it. Thanks again.
10-06-2013, 04:56 PM   #22
LB1103's Avatar
As far as I know, there is no way to adjust the brightness level of the viewfinder readout. I can sympathize with not being able to see the level indicator in very bright conditions, as I have a tendency to tilt the camera inadvertently. Pentax does offer a focusing screen that is basically a "rule of thirds" grid (model # ML-60) which I have purchased and installed in my iis that is helpful for me, not only with keeping the camera straight but also with composition.
10-06-2013, 05:03 PM   #23
jatrax's Avatar
I didn't think so I used to live in Pittsburgh.
I wear glasses but my prescription allows me to set the diopter on the camera for my eye without glasses. So when shooting I take the glasses off and just use the camera viewfinder. Not everyone can do that of course. They make a number of different eyecups that are larger and work better with glasses. I used a large curved one for a while until I just went without the glasses.
But in general glasses and viewfinders don't mix well.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, lens, lenses, pause, pentax, pentax k-5, stock
Be Gentle, I'm New firebrand Welcomes and Introductions 4 04-24-2012 11:40 PM
Macro Gentle Landing eaglem Post Your Photos! 7 04-06-2012 10:40 PM
With You on this Gentle Ground Bannister Welcomes and Introductions 4 02-12-2012 04:50 PM
Macro Gentle Landing eaglem Post Your Photos! 2 12-20-2011 09:52 PM
Macro A Gentle Landing eaglem Post Your Photos! 5 02-20-2011 04:17 PM
All times are GMT -7. The time now is 08:20 AM. | See also: NikonForums.com, part of our network of photo forums!
