10-20-2012, 05:05 PM   #1
Hot K-5 means louder shutter?
JUst did some shooting yesterday on a very hot day (38 dec C or more in the shade) at the local agricultural show.
Shooting in the late afternoon I noticed that after a few hours of use the camera shutter sound was 'louder', more like the K-x than hushed like the K-5 normally is. After night fell and things cooled down a lot, including the camera, the shutter returned to being its usual quiet self.
Everything worked fine, all the images were OK and I never stopped shooting, so no problems or complaints. But it left me curious about why. At home, after checking the EXIF of a sample of shots, the camera body temperature was ranging 30 - 42 deg C, possibly higher, which means for much of the day the K-5 was operating outside of its spec temperature range of −10 to 40 C.
My guess is that sustained use in hot conditions generated internal heat, which produced some minute changes in the physical tolerances or properties of the camera internals (a tiny expansion or softening of some shutter-box components, including the mirror dampening bits?). Hence the temporarily different acoustics.
Anyone with similar experiences?
10-20-2012, 05:11 PM   #2
Ex Finn.'s Avatar
Everything worked fine, all the images were OK etc, so no problems or complaints. But it left me curious about why. At home, after checking the EXIF of a sample of shots, the camera body temperature was ranging 30 - 42 deg C, possibly sometimes higher, which means for much of the day the K-5 was operating outside of its spec temperature range of −10 to 40 C.
I believe you are the first to notice this behavior, very interesting observation and worth noting.
10-20-2012, 05:26 PM   #3
QuoteOriginally posted by Ex Finn. Quote
Thanks. Everything kept working fine. In fact the camera worked more efficiently in the heat than I did, that's for sure.
10-21-2012, 06:22 PM   #4
I notice the shutter noise is different depending on shutter speed. If it is very fast, 1/2000 and up, it clunks.
10-21-2012, 06:55 PM   #5
QuoteOriginally posted by derekkite Quote
Same observation here.
10-22-2012, 05:53 AM   #6
Newer noticed any change in sound in hot (like in Asia) and cold (like in winter Finland)
shutter speed effect not also noticed...i will try to check this later today.
10-22-2012, 07:20 AM   #7
RonHendriks1966's Avatar
To be honest, I don't know. I did use my K-5's in hot temperatures and got them warmed up to 42 degrees C, but didn't pay any notion to the shuttersound at the time.
10-22-2012, 08:04 AM   #8
It was just a curiosity to me. Everything worked fine, and still does.
Most of the shutter speeds were pretty slow when I had the camera running hot - less than 1/250.
Aside from the heat, maybe the lens in use at the time the shutter noise seemed loudest also contributed - a Tamron 17-50 2.8. Perhaps some lenses simply help muffle the shutter/mirror noise better than others?
So many inconsequential, geeky things to obsess about and ponder
10-24-2012, 01:00 AM   #9
I haven't noticed any change in shutter sound when shooting in 39-45 deg C this summer. Even if it was a bit louder, it surely wasn't as loud and clunky as K-m shutter sound.
10-24-2012, 01:10 AM   #10
Hmm, just an educated guess. If it was so hot, it must have been very bright as well. That means high shutter speed and that sounds different.
camera, day, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, shutter, temperature
Can't use V5 (or other remote trigger) as shutter trigger in hot shoe above 1/180? jake14mw Flashes, Lighting, and Studio 14 07-16-2012 04:14 PM
Gobo? Anyone know what it means? Ubuntu_user Photographic Technique 14 09-27-2011 07:50 PM
What auto flash means? liukaitc Troubleshooting and Beginner Help 2 03-13-2011 08:30 PM
Photozone Reviews Tamron 70-200 2.8 HOT! HOT! HOT! JHD Pentax SLR Lens Discussion 31 02-03-2011 09:11 AM
Is the whirring sound from SR louder on some cameras? Aegon Pentax DSLR Discussion 10 09-07-2008 04:52 PM
All times are GMT -7. The time now is 03:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
