Originally posted by regor The histogram is calculated from the embedded JPEG in the RAW file, and is therefore representative of the PP JPEG, not that of the un-processed RAW. Hence it will be affected by the settings used for PP the JPEG image in the camera (contrast, colors, WB etc.)
Ah Yes. So when I first import and look at the histogram in library mode it is of an imbedded jpeg and is the reason when I load the raw image into develop mode the peaks are compressed. Perhaps I should check and see if the jpg in camera settings are set at extremes.
Thanks
