10-23-2012, 06:59 PM   #1
tabl10s's Avatar
Exposure Compensation And The On-Board Flash.
I just discovered that the light output can be controlled with a series of test shots. Do I still need my Metz 58AF-2?
10-23-2012, 08:48 PM   #2
callmeraymon's Avatar
Would you like my address, so you can ship it to me?
10-23-2012, 09:26 PM   #3
tabl10s's Avatar
I don't do a lot of flash work and didn't think of using the '58(I've never used it). I'll let you know.
10-23-2012, 09:38 PM   #4
What until you put a bigger lens on, say something with a 72mm or bigger filter and your will see the eclipse of the lens in your photos with the built in flash.
10-24-2012, 01:37 AM   #5
abmj's Avatar
The on-board flash, with its tiny light source and 'close to lens axis' is really only good for putting a tiny bit of fill light into some shots to reduce and soften shadows. As a primary lighting source, it pretty much just serves to make people look bad. Remember the rule of thumb, the larger the light source, the softer the light. That is why big soft boxes and large reflectors make such nice light. The inverse is also true. With that little light, it will be harsh and flat.
10-24-2012, 04:13 AM   #6
Yes, EC also regulates P-TTL exposure. Even with P-TTL flash you need to tweak EC to adjust for scene bright/darkness,
just as you do in non-flash photography. EC is just easier to reach than FEC, which is burired in a menu.
Regards,
--Anders.
10-24-2012, 06:10 AM   #7
tabl10s's Avatar
@Call,
Sorry man, I'll now Keep it.
10-24-2012, 02:42 PM   #8
Shucks
camera, dslr, exposure compensation, k-5, k-5 ii, k-5 iis, k5, pentax k-5
newbie question - flash exposure compensation kkx Pentax K-5 11 02-01-2012 10:42 PM
Camera exposure compensation vs flash compensation raider Photographic Technique 4 09-29-2011 05:02 PM
Flash vs. camera exposure compensation jms698 Photographic Technique 2 08-22-2009 04:27 PM
Flash Exposure Compensation Question roger.hayslip Flashes, Lighting, and Studio 4 02-28-2008 08:25 AM
540 FGZ + K10D flash exposure compensation WMBP Pentax DSLR Discussion 12 12-06-2007 05:26 PM
All times are GMT -7. The time now is 05:44 PM. | See also: NikonForums.com, part of our network of photo forums!
