Originally posted by Adam While you've got a valid point about the terminology, I think even the old K-5's AF was precise enough in that respect.
For f-ratios in the range of f/1.4-f/2.8, I'm sure the new f/2.8 sensor will bring improvements. As you can see from the
ColorFoto Test (thanks StigVidar!), PDAF systems aren't that great in terms of accuracy compared to CDAF.
Originally posted by Adam Most people are going to be more interested in the type of accuracy I'm referring to, I think.
I don't know, but perhaps it is worth bearing in mind that if someone shoots Pentax, they are unlikely to have fast AF high up on the priority list.
In any event, please make sure you use the term "AF accuracy" to refer to the level of precision an AF system achieves in static situations (just like ColorFoto did) and use a different term for what you are interested in.
I'd refer to the latter as "AF speed", which has two aspects
- how quickly can a lens get through its focusing range and
- how quickly can a camera lock and confirm focus on a target*.
* If the target is moving, we are talking about "continuous AF speed".
Surely point 2. above is slightly influenced by point 1. but not that much in real life when the lens is already focused near the point it needs to be.
Coming back to the question what most people are more interested in, I'm very happy that Pentax chooses to be slow but accurate. Canon partly achieves their AF speed by having a higher tolerance of what they consider "sharp". This allows the AF system to stop the focusing process earlier and it may even omit a double checking phase at the end (EDIT: The Canon AF does indeed omit a double-check in case the shutter release button is fully pressed and the lens only needs to adjust the AF a little. In other (half-pressed) cases, Canon AF also double-checks).
