10-26-2012, 06:59 PM   #1
LCD and Viewfinder Info Differing
Hello Pentaxians,
I am a new member. This is my first post except for my "introducing myself" post. I just wanted to mention this to see if anyone else has an idea of why this would happen. When I go shooting with my K-5, in TAV mode, it seems like the LCD ISO reading differs from the ISO reading that I see in my viewfinder. The other settings which I set myself in TAV mode (F-stop and shutter speed) read the same in both screens and when I check my image stats they state the ISO I saw in my viewfinder as the ISO used to shoot the image. Does anyone know why the different readings would appear like that. I started thinking that maybe my software needs an update to coordinate the readings, but am not sure. I actually go along with the viewfinder readings for the ISO and get excellent shots, but am curious why the LCD screen would display a different ISO reading than the viewfinder. Maybe there is no problem, I just would like to find out if there is possibly something I need to configure or if someone else is familiar with this happening. I have used a Sigma 150-500, Pentax 18-55 AL II, and Pentax 55-300 with the camera. I would also like to add that I regard the K-5 as an excellent product.
Thanks,
Casey
10-26-2012, 08:23 PM   #2
Ole
Ole's Avatar
The ISO reading in TAv mode shifts with the light of the scene so if you move the camera between reading the top LCD and reading the viewfinder you may get different results. Also light can enter the viewfinder through the eyepiece when not covered by your eye and affect the measured light. Therefore the ISO could be set to a different value when your eye doesn't cover the VF than the value you see in the VF.
The value on the top LCD shall be the same as in the viewfinder at the same point in time. You could ask a friend to read you the value from the top LCD while you read the value in the viewfinder!
10-27-2012, 07:56 AM   #3
Thank You
Ole,
I was thinking the same as what you told me. I just wanted to make sure it was that basically, and get a second opinion.
Thanks,
Casey
camera, dslr, k-5, k-5 ii, k-5 iis, k5, lcd, mode, pentax, pentax k-5, readings, viewfinder
Viewfinder info readout New Englander Pentax K-r 3 04-01-2012 07:57 PM
LCD preview and info not visible when cable release attached jasonpiers Pentax K-5 2 03-25-2012 01:04 PM
LCD Viewfinder for K-x? Brian K Pentax Camera and Field Accessories 2 01-02-2012 09:24 AM
No LCD viewfinder info on Pentax super A thehorologist Pentax Film SLR Discussion 10 10-17-2011 10:25 AM
viewfinder/LCD screen tiamaria2326 Pentax DSLR Discussion 3 04-21-2011 08:02 PM
All times are GMT -7. The time now is 01:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
