Originally posted by snostorm BTW, I don't doubt that the K-5IIs captures sharper, higher resolution images, I just don't think this demonstration proves anything.
I fully agree.
Open questions:
- Has the same lens copy been used on both cameras?
- Why use different exposure times?
- Why does the focus point seem to be on the "S" rather than on the "O" in the K-5 shot?
- Has a tripod been used and were both cameras fired the same way (e.g., using a remote and mirror lock-up)?
- Are you comparing JPG engines or did you convert RAW files with the same converter using the same settings?
- Has the lens received AF micro-adjustment on both cameras?
- Under which (identical?) conditions was the micro-adjustment performed?
- What method was used to ensure that each camera obtained optimal focus?
- Why do you not apply the necessary capture-sharpening to shots from the K-5? The Bayer AA-filter is designed to create (necessary) blur and this blur must be undone (ideally with deconvolution, but unsharp mask type sharpening is OK).
I'd say test conditions that lead to dramatic differences like shown here, but also to
very subtle differences in other situations, aren't entirely reliable (yet).
Adam, could you please make both full images available so that we can compare where the centre of best focus is in both respectively?
