10-29-2012, 02:25 AM   #1
Dust Removal System Question
I have a K-10 set to activate the dust removal system on start-up, and you can hear and feel the sensor shake. I have my K-5 set up the same way but don't hear or feel anything. Is that normal for the K-5 or do I have a problem that needs to be checked?
10-29-2012, 02:30 AM   #2
It's normal. K10D is shaking the sensor, but K-5 is using ultrasound.
10-29-2012, 02:49 AM   #3
amoringello's Avatar
in other words,
K10 sensor cleaning == almost useless. I wet cleaned my sensor almost quarterly or more often.
K5 sensor cleaning == amazing. I have not cleaned my sensor in nearly two years of owning it.
If you listen closely, you *should* hear a moderately-high pitched whine in the K5 as it starts up or as you manually use the sensor cleaning form the menu. If you truly hear *nothing*, then yes there may be a problem.
10-29-2012, 02:58 AM   #4
VisualDarkness's Avatar
QuoteOriginally posted by amoringello Quote
in other words,
Well, it depends on you hearing. The high pitch sensitivity is usually the first to go with age or damage.
10-29-2012, 03:12 AM   #5
Ash
Community Manager
Ash's Avatar
But it is audible, and it does work.
Viva la difference.
10-29-2012, 03:34 AM   #6
Thanks all. I'm 50 and according to my wife can't hear anything. then again my mother said the same thing when I was 18. Might be a selective thing.
10-29-2012, 03:43 AM   #7
RobG's Avatar
in other words,
I have had the same experience with my K200 and K7. Well, except I only use a blower on the K200.
10-29-2012, 08:27 AM   #8
Jatcat's Avatar
QuoteOriginally posted by jrpower10 Quote
LOL !!
Oh,, and did you hear about the new men's disease?
It typically occurs after you suffer middle-aged hair loss:
When you walk into the kitchen and can't find a spoon; it's called Male Pattern BLINDNESS !!
10-29-2012, 08:35 AM - 1 Like   #9
QuoteOriginally posted by Jatcat Quote
Dang, I bet I was born with a chronic condition of that.
camera, dslr, dust, k-5, k-5 ii, k-5 iis, k5, pentax k-5, removal, system
K5 dust removal system Tony3d Pentax K-5 5 09-03-2011 11:49 AM
Dust removal system Luin Gor Pentax K-5 5 03-14-2011 06:27 AM
Dust Removal Question Verglace Troubleshooting and Beginner Help 4 03-13-2011 10:31 PM
K 7 Dust Removal Question tpeace Pentax DSLR Discussion 3 03-19-2010 02:46 PM
Dust Removal System Shootout RiceHigh Pentax DSLR Discussion 28 03-28-2007 03:08 AM
All times are GMT -7. The time now is 05:48 AM. | See also: NikonForums.com, part of our network of photo forums!
