https://www.pentaxforums.com/forums/pentax-k-5/207505-pentax-k-5-iis-vs-k-5-ii-take-two.html
Okay now tell me again the photos of the normal version look oversharpened.
Sure technically this is cheating and the S version should look better but the normal version under went the processing very well if you ask me. I doubt you can even tell them apart at these zoom levels so... how much of a differnce would it make for a real print?
Now i would love to see someone finally point me out to the details i'm missing, if they are so easy to spot for you guys why not point them out?
@Jim & Alizarine , sharpening does not need to take more time, my is for example done automaticly by lightroom when importing. It sees what lens and camera i used and it aplies the correct preset. Removing moire however does take more time since you can not automate the process.
I know that moire is not much more then with the normal version but how ever you turn it it is more likely you get it, so... i would spend more time in processing with a camera without AA filter. Thats not a bad thing if you get something for in return.
Thats how i've set it up though, your experience will indeed be different that's why i'm trying to cut to the core of things.
