12-02-2012, 06:50 AM   #16
JohnBee's Avatar
QuoteOriginally posted by cbaytan Quote
Shown with arrow pink and green building face is not a moire, is it? If not I am not seeing any moire.
Yes that's moire
12-02-2012, 06:55 AM   #17
I was stopping on the way back from doing some bird photos- certainly can't see any hint of moire in those. The top 4 in my photostream are recent K5-IIs photos, the rest are trusty old K7:
Flickr: asgr's Photostream
12-02-2012, 06:58 AM   #18
I meant to add a comment on PF. I'll need to do some tests, but one added benefit *appears* to be that PF is much better controlled on the K5-IIs than on my K7 in high contrast lighting situations. Can't comment re K5 or K5-II.
12-02-2012, 08:00 AM   #19
GDRoth's Avatar
Thanks asgr.................so how would you PP to get rid of it?
12-02-2012, 08:27 AM   #20
Just to demonstrate it is Moire, here's the same seen but at F4 (previous was f5.6).
Both were shot with 35mm Ltd. You can see the coloured bands going at a different angle now. This lens is probably too sharp for it's own good :-D It's noticeable how blurry (but moire free) similar shots with my K7 are.
As for removal in PP, I haven't tried yet. If somebody wants to have a stab, the raw is at https://dl.dropbox.com/u/10495241/_IGP6273.DNG
Looking around, LR4 looks like it might be able to do the job. I only have LR3, and that doesn't have any moire removal tool per se.
Cheers,
Aaron
12-02-2012, 08:59 AM   #21
QuoteOriginally posted by asgr Quote
Aaron
I say don't bother with the moire correction , just use the F4 version, moire in that sample is so smooth and straight distributed, almost anybody can buy it as a wall paint, or just select the area and decease the color saturation in PS, that'll do.
12-02-2012, 09:21 AM   #22
gooseta's Avatar
in lr4 there is a moire brush, not sure how well it works tho
12-02-2012, 11:50 AM   #23
QuoteOriginally posted by gooseta Quote
It does OK:
12-02-2012, 12:06 PM   #24
Otis Memorial Pentaxian
What an excellent thread idea! If the community can show some restraint (more photos, less verbiage) it might become a valuable resource for people considering purchase of the K5 IIx.
12-02-2012, 03:16 PM   #25
adobe camera raw has a brush too, works almost the same as LR's
it makes the left building a little whiter, but no moire after the brush.
12-02-2012, 03:32 PM   #26
Here's some 645D and D800E moire:
More at: Nikon D800E vs. Pentax 645D - Moire - PentaxForums.com
More from the 645D:
(100% crop)
(200% crop = negligible)
12-02-2012, 04:49 PM   #27
Great to see LR4 does the job easily.
I was surprised about it's presence on the left building. It must have something to do with the window pattern being offset.
A
12-02-2012, 05:39 PM   #28
Dr_who's Avatar
Moire with K5
I'm not to concerned with moire, it happens from time to time no matter then camera. This is a example from the plain ol K7. Some material is just very moire inducing and others are not.
The lens used was the DA* 50-135mm
12-02-2012, 05:55 PM   #29
This is true, some materials are moire hell, especially fabrics like the one you posted, but color moire is easy to fix.
from the photo i understand that you shoot weddings, how often do you see moire like this? would you get the k-5iis or you think its going to be a problem ?
there is some residual moire (pattern not color) near the pocket, maybe with a stronger brush...
12-02-2012, 06:55 PM   #30
Dr_who's Avatar
QuoteOriginally posted by obscura Quote
I already bought one, as you said its fairly easy most times to edit, also it showed up in that wedding maybe 10-15 times out of hundreds. You really have to be the right distance, with the right camera settings most of the time and as many have pointed out adjusting the Fstop can drastically reduce those chances as well. Generally speaking I almost never see Moire, just this wedding in particular did the groom have something that really induced it.
camera, dslr, issue, k-5, k-5 ii, k-5 iis, k5, pentax k-5, pictures, users
Show us your grain! artobest Film SLRs and Compact Film Cameras 354 04-04-2012 12:13 PM
Thematic Show Us Your FIREWORKS! (And other end of year shots!) MSD Mini-Challenges, Games, and Photo Stories 4 01-08-2011 10:12 AM
show us your junkers Lowell Goudge Post Your Photos! 7 03-02-2009 02:58 PM
Show us your storms! dawsonjm Post Your Photos! 41 12-15-2008 08:07 PM
Show us your gear! blwnhr Photographic Technique 5 11-09-2007 01:53 AM
All times are GMT -7. The time now is 03:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
