12-02-2012, 08:19 PM   #31
Class A's Avatar
Apparently without noticing, Adam has produced another "real world moiré" example; the f/5.6 cacti landscape shot shows some nasty moiré (right most cactus).
12-02-2012, 08:22 PM   #32
Class A's Avatar
QuoteOriginally posted by Dr_who Quote
I'm not to concerned with moire, it happens from time to time no matter then camera.
While it is true that even cameras with a Bayer-AA-filter can produce moiré as well, they'll do that in a lot less circumstances, i.e., the likelihood of moiré occurring is much lower.
12-03-2012, 05:05 AM   #33
JohnBee's Avatar
QuoteOriginally posted by gooseta Quote
You say that more detail can be extracted from the k5ii with sharpening, who says you cant extract detail on the k5iis, I have seen many cases in my images where a lot of feather detail has been extracted with a bit of sharpening
Sorry, I should have said(to clarify) that the K-5 II can TOLERATE more sharpening than the K-5 IIs due to the nature of the softer images. IOW. you need to apply far more sharpening the K-5 II in order to get it into the K-5 IIs level of detail. Whereas the K-5 IIs doesn't need much sharpening at all(if any) under normal circumstances. Not to mention, where you will hit a maximum threshold very early on in terms of oversharpening.
Hope this helps clear things up.
12-03-2012, 05:06 AM   #34
JohnBee's Avatar
It does OK:
Attachment 149769
Very impressive!
12-03-2012, 07:08 AM   #35
QuoteOriginally posted by JohnBee Quote
Very impressive!
I was impressed too. Select brush, apply to area of moire, adjust slider, moire gone, with minimal impact on underlying image.
DxO Optics Pro moire removal slider, however, totally failed to make any impact on the building, ditto PSP X' s Moire Removal tool, even though PSP X worked fine on the colour moire on Adam's cacti.
I wonder what is behind how different tools like LR or DxO or PSP assess and process moire? Are they checking for different types of moire? That seems possible. So one tool might not remove all moire forms.
12-11-2012, 10:49 PM   #36
Here's some moire from my phone. Spotted this in a shot I just took for a marketplace listing. Guess it's got supreme filterless 5MP resolution
BlackBerry 9810  Photo
12-12-2012, 02:35 AM - 1 Like   #37
Hi
Be careful not to trick yourself thinking you have copped a dose of Moiré by judging what you see on your computer screen.
Here is an example. Safe the image to disk, than open it in, say in PS, hit Alt+Space to reduce the image (or zoom out in any other program) and you will see what I mean. Depending on the original size image this can happen anytime by displaying it "fit to screen" without checking "actual pixels" There can be a few variations here and there depending on the screen quality.
Greetings
12-12-2012, 09:24 PM   #38
I've posted some samples of moire from my K-x before, but as falconeye explained, it's just one type of moire, luminance moire. Weird thing is I don't see a lot of moire in the IIs shots in Flickr...
[IMG]s9.postimage.org/75i5lj4pb/Untitled_1.jpg[/IMG]
i also have a sample of color moire on fabric, I'll post it when I find it.
12-13-2012, 02:21 AM   #39
I played with ways of removing moire in CS5 the other day. One pretty effective way of removing it is using a motion blur, but that motion blur must be set to run "across" the pattern. In other words, the first example of the building exhibiting moire displayed almost perfectly vertically (the first time I've seen that), and so a motion blur that was set to run vertically also would do nothing to counter it; it must be set to blur horizontally.
I wonder if the DxO and PSP processing bases its moire removal on a vertical detection algorithm. It seems unlikely in a way, especially since in the building we are mainly seeing color moire which shouldn't need to be undone by blurring (probably by some sort of averaging of the pixel colors).
Anyway, if you have a chance, I wonder if rotating the image and trying DxO and PSP again would yield different results. Probably not, but I'd do it if I had either of the programs.
P.S. Removing color moire can, If I remember correctly what I did, be controlled, if not completely removed, by the color noise filter in ACR/LR. I suppose that any RAW filter or general image editor that offers color noise reduction could be effective also with color moire.
12-13-2012, 02:27 PM   #40
RobG's Avatar
Has anyone used the "spurious colour noise" adjustment in the Pentax camera utility to control colour moire? I don't have a photo of my own which demonstrates obvious moire to experiment with.
01-22-2013, 06:28 PM   #41
MOIRE MOIRE MOIRE
Ok where are the others that spoil your pictures? still waiting....
01-22-2013, 10:55 PM   #42
QuoteOriginally posted by cbaytan Quote
Posted this in another thread, but since you seem very enthusiastic on it...
here's a 100% crop
01-24-2013, 11:29 AM   #43
Aegon's Avatar
Here's some moire from a D600, which is supposed to have a filter.
01-24-2013, 09:34 PM   #44
QuoteOriginally posted by Aegon Quote
I get some similar moire in clothes from my K-x at times, but not as bad as the one I got from the K-5 IIs... which, so far, happened only once. So, still not fearful of moire.
10-11-2013, 02:21 AM   #45
froeschle's Avatar
Not with a K-5IIs but with a Ricoh GR (with very similar sensor):
Ricoh GR, f5.6, ISO 100,
2541x1793 from 4928x3264 scaled to 1200x847,
some post-processing (due to yellowness and weak contrast of original).
camera, dslr, issue, k-5, k-5 ii, k-5 iis, k5, pentax k-5, pictures, users
Show us your grain! artobest Pentax Film SLR Discussion 354 04-04-2012 12:13 PM
Thematic Show Us Your FIREWORKS! (And other end of year shots!) MSD Mini-Challenges, Games, and Photo Stories 4 01-08-2011 10:12 AM
show us your junkers Lowell Goudge Post Your Photos! 7 03-02-2009 02:58 PM
Show us your storms! dawsonjm Post Your Photos! 41 12-15-2008 08:07 PM
Show us your gear! blwnhr Photographic Technique 5 11-09-2007 01:53 AM
All times are GMT -7. The time now is 11:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
