06-30-2013, 12:00 PM   #211
Into The Lens's Avatar
Here are some "day by day" shots I took at this year's FIJM. Most pictures where shot with a Pentax K-5 with a few shot with a Fuji X100s here and there...
"Sunpeakin' at the Jazz Fest" ― (Fuji X100s)
Day 1 ― Friday, June 28, 2013
"Scène Blues Loto-Québec's" sound board and crowd. (Fuji X100s)
Larry McCray ― Scène blues Loto-Québec.
Joel DaSilva & The Midnight Howl
Joel DaSilva & The Midnight Howl (feat. Larry McCray)
"Beer Stand" ― Festival site (Fuji X100s)
Day 2 ― Saturday, June 29, 2013
"Crowd at the Blues Scene" ― (Fuji X100s)
"Mister Soundman..." ― Place des Festivals. (Fuji X100s)
"Looking for the Scene" ― Festival site (Fuji X100s)
07-01-2013, 09:11 AM   #212
somaticsweater's Avatar
hello all... i only just recently picked up a k-5 iis and use it pretty much exclusively just for concerts. i was actually debating between a canon 6d and nikon d600/d7100, but the pentax eventually won out. anyways, here are 2 recent photos that i just took of a band called "someone still loves you boris yeltsin". the lighting was crap and i shot at iso 5000 - pretty happy with how it handles noise. fyi, you can see the rest of the photos here.
07-01-2013, 10:05 AM   #213
QuoteOriginally posted by somaticsweater Quote
Nice shots, somaticsweater. I was thinking of maybe upgrading to a K52S for it being apparently a lot better than the K5 in low light (better auto focus performance). Did your AF struggle a little when you shot these. I can tell just by your photographs the lighting was poor. I shoot at lot in these bad conditions and wish the K5 performed a little better at that sometimes.
07-01-2013, 10:30 AM - 1 Like   #214
QuoteOriginally posted by Into The Lens Quote
thanks! AF-wise, this camera doesn't struggle... at all! sound-wise, it is definitely noisier than what i'm used to though (using it with a tamron 17-50). it's also very snappy especially compared to the other camera i use for concerts (a fuji x-pro 1). fyi, i use the back-button focus technique on the k-5 iis.
i've used canon DSLRs in the past and their dynamic is so poor compared to the pentax - i've only had the camera for a short time, but barely ever (actually never) saw any highlight clipping.
07-10-2013, 04:46 PM   #215
Couple recents from a local venue. K-5 w Pentax A 35-105 f3.5. Bit of a colour cast, unfortunately, due to LED lighting swamping the scene with purple, magenta and red.
qt 3.141
Smiling again
Backing vocals
07-10-2013, 06:24 PM   #216
joe.penn's Avatar
Good shots @rawr .
FYR: A quick flash of CTO fixes this color cast while still keeping the proper ambient light within the scene.
07-10-2013, 06:54 PM   #217
They are good and some color cast is fine. That's what the lights were doing and you captured the night.
07-10-2013, 11:26 PM   #218
QuoteOriginally posted by joe.penn Quote
CTO
Pardon my ignorance... but what's that.
After looking at the images again, I've just run the main ones from that gig through Pentax Digital Camera Utility v4, which has great WB features, inc a very handy multipoint grey point selector. I used that to select 3 grey points off the microphones to get a better colour rendition. The results look natural so I may update these images at some stage. PDCU seems to do very well with Asian skin colours, in particular, which is probably not a surprise.
07-11-2013, 02:18 AM   #219
awaldram's Avatar
Its a gel flash filter (colour temperature orange)
Joe how would firing an orange colored flash have helped in this situation ?
IMO it would have aggravated the light balance
Surely using CTB (Colour Temperature Blue) woudl be the correct approach.?
It could also have been corrected by using a custom WB to achieve accurate skin tone but then the background would have turned blue
07-11-2013, 03:50 AM   #220
QuoteOriginally posted by awaldram Quote
Aha. But I never use flash at gigs. So a CTO would be little assistance. Unless using CTO in PP is what is being discussed? But I already routinely work with the colour temperature adjustments (hue/saturation/luminance etc) for orange in Lightroom.
Most times I just hunt for something grey equivalent in the scene in PP to help adjust WB. It's never perfect but it brings me close enough, usually.
07-11-2013, 04:18 AM   #221
awaldram's Avatar
Snap I shoot raw and correct CB in post usually by using 'click white' in after shot, Generally the colour cast caused on non main lit subjects adds atmosphere .
07-11-2013, 07:05 AM   #222
Agree. CB related stuff like perfect skin tones at gigs are nice to obtain when it's possible without too much effort. Otherwise I just roll with atmospheric.
07-11-2013, 08:57 AM   #223
joe.penn's Avatar
Using CTO will help enable a clean consistent and uniform tungsten white balance which should in most cases match near exact to the actual stage lighting. As for which CTO to use, that depends on how much ambient light is within the scene - I keep a 1/2 CTO attached to my main flash at all times. Unfortunately PP can not fully correct white balance issues when the scene includes lighting from many different types of light sources, gel'ing at time of exposure fixes this issue.
And that is where gel'ing comes into play.
Of course, none of that matters if you don't use flash anyways
07-11-2013, 09:38 AM   #224
mattb123's Avatar
Dirty Dozen Brass Band at the local watering hole last night. Great show!
I didn't use a flash (I usually don't for concerts) so I just shot RAW and set WB myself either with the dropper or manually.
K-5 & Rokinon 8/3.5
K-5 & Tamron 28-75/2.8
07-11-2013, 09:54 AM   #225
awaldram's Avatar
Ah I get you, instead of using CTB and daylight WB you use CTO and Tungsten ...it all becomes clear
Thanks
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax, pentax k-5
Has anyone used the O-GPS1 for nightsky photography? CDW Pentax K-5 4 11-17-2011 03:15 AM
Anyone buy their K-5 from ajrichard.com? Designosophy General Talk 14 09-23-2011 10:11 AM
has anyone used this hood for DA 35mm f2.4? sany Pentax SLR Lens Discussion 8 05-27-2011 05:20 PM
Has anyone used their DSLR w/ macro to capture a 35mm negative? geekette Pentax Film SLR Discussion 22 05-02-2011 06:28 PM
Has anyone used a stabilized Sigma lens with their Pentax yet? ftpaddict Pentax SLR Lens Discussion 17 09-06-2009 12:43 PM
All times are GMT -7. The time now is 06:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
