Originally posted by mikeSF good advice. Unless the spots are moving or other lights changing intensity, i do the same. Just to protect the odd hot spot, i tend to shoot with a little bit of negative EV compensation and bring things up in post. Marc Sabatella turned me onto a great trick for concerts of underexposing in order to get a faster shutter to counter motion blur (in flash-less photography); as a result, in dark venues, i expose to the left as a rule, then pump up exposure as much as a couple of stops in post. The sensor on the K5 really allows this with minimal noise.
BTW, in my previous post, I meant in Live View, not view finder. (sorry for the confusion)
So, technically speaking, do you spot meter on faces, check a few shots in live view to see what they look like, then bring down the EV Compensation to -1 or -2? Is that how you'd do it?
Just one thing I need to understand here is, when people say underexpose 1 to 2 stops (negative EV compensation), does this mean bringing down the EV to -1 or -2 or 1/3 = 1 stop. I don't use the EV compensation since like I said I usually look at a few shots on the live view screen to see how they turn out to help me set things up. So if I'd compensate to -2 EV and meter to the center of the meter and take a shot, I guess it would show underexposed in Live View, right? Since I would rely on the Live View screen to "meter" my shots it wouldn't be possible to "negative EV compensate" in my case! I'll try this approach next time I shoot. I can see how I could shoot at higher speeds using this trick now. Very interesting.
Oh and BTW, great shots indeed Mike. And thanks for your help too.
