12-20-2012, 01:11 PM   #1
Importing K5ii DNGs into iPhoto
I tried to import DNG files from my new K5ii into iPhoto and get a message that the format is unreadable. I have iPhoto 6 and run OS 10.6.8. I use Photoshop Elements 10 for photo editing and RAW file work.
Importing DNG files from my older K10 works fine.
Any ideas why? Any solutions?
Is it a firmware issue? (The firmware on the K5ii is V1.0 whereas the firmware on the K10 is V1.31)
12-20-2012, 01:28 PM   #2
Anvh's Avatar
Most likely iPhoto, seeing that the DNG is from a K5ii.
It depends on how the software implements the DNG support, with DNG the camera profile is inside the DNG file but some software manufactures decide to only use camera profiles they have build.
So iPhoto might be ignoring the build in profile and since he does not have a profile on his own he can not make an image from the information.
That might be the case here.
12-20-2012, 01:35 PM   #3
boriscleto's Avatar
DNG is a universal format. They should read just fine. What version of iPhoto are you using and do you have the latest RAW compatibility update? There have been 2 updates since the K-5 ii was released and still no K-5 ii PEF compatibility.
https://www.pentaxforums.com/forums/pentax-k-5/205815-new-k5ii-old-iphoto-09-a.html
12-20-2012, 02:59 PM   #4
Anvh's Avatar
QuoteOriginally posted by boriscleto Quote
Does it have PEF?
And yes DNG is universal by design but... not every software manufacture does it that way, they arent forced by Adobe to do it.
12-20-2012, 03:12 PM   #5
boriscleto's Avatar
QuoteOriginally posted by Anvh Quote
Does it have PEF?
Of course iPhoto has PEF compatibility, just not for the K-5 II or IIS. Apple's implementation of DNG is to provide universal RAW. The only DNGs that I know of that don't work are those created by VueScan. Those I have to process with Raw Photo Processor.
Raw Photo Processor (RPP)
12-20-2012, 04:27 PM   #6
Anvh's Avatar
I mean does the K5 mkII actually has PEF, i don't believe so
If that's true about iPhoto then the DNG should simply work... strange.
12-20-2012, 04:41 PM   #7
boriscleto's Avatar
The K-5 ii has PEF even though the K30 and K-01 don't.
12-21-2012, 09:36 AM   #8
krs
I had a problem with PEF files and Lightroom for the K5iis. Come to find out adobe had to do some updates for the K5ii/iis to be able to read the PEF file. Maybe the same applies here?
Note: Until the LR 4.3 release was available, I changed the format to DNG in the camera, and that worked fine.
12-21-2012, 10:05 AM   #9
Anvh's Avatar
Ah okay, thanks =]
12-21-2012, 10:07 AM   #10
Anvh's Avatar
QuoteOriginally posted by krs Quote
Read my first comment and you've your answer.
Although i aint sure how iphoto has implemented DNG.
camera, dng, dslr, files, firmware, iphoto, k-5, k-5 ii, k-5 iis, k10, k5, k5ii, pentax k-5
New K5ii, old iPhoto 09 greg_77 Pentax K-5 6 11-19-2012 09:30 PM
Color Profiles when importing into Apple Aperture MidwestPentax Pentax DSLR Discussion 2 08-09-2012 04:17 AM
Importing into lightroom ends in tears wjt Digital Processing, Software, and Printing 16 04-21-2012 05:23 AM
Importing K5 PEFs into iPhoto dh87 Troubleshooting and Beginner Help 6 08-03-2011 12:23 PM
Problem importing images into iphoto - purple haze devonteran Pentax DSLR Discussion 4 03-15-2011 03:44 PM
All times are GMT -7. The time now is 10:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
