12-23-2012, 01:48 PM   #1
K-5 built-in flash
I have had my K-5 now for about 6 or 7 months and just love it. I do mostly landscapes and outdoor stuff.
Well, I thought I would play around with the built-in flash and get used to how it operates. Well, apparently it doesn't work.
It doesn't even sound like it is charging when popped up.
Has anyone else had any issues with the built-in flash?
Thanks in advance.
Alan
12-23-2012, 02:35 PM   #2
Probably for the best. built in flashes are the worst.
12-23-2012, 03:29 PM   #3
I agree - but on a new camera it should at least work ... if for nothing more than to trigger off camera flash ... even though for that I use wireless ...
12-23-2012, 03:34 PM   #4
Into The Lens's Avatar
Did you try it in the green mode? Also, I think it doesn't work at speeds faster than 1/160 sec...
12-23-2012, 04:00 PM   #5
QuoteOriginally posted by Into The Lens Quote
It is 1/180, you could put it in X mode just to be sure.
12-23-2012, 04:01 PM   #6
I tried it on every setting that camera has lol ... in any case ... when you hit the button to raise it up should you not hear it charging? Or at least get some indication that it is on?
The icon flashes indicating that flash is needed but when I pop it up - nothing. Press the shutter release - nothing ...
12-23-2012, 04:06 PM   #7
I don't hear anything on mine, built in flashes are usually pretty quiet, my K100D never made any noise either.
Do you have a photo taken with the flash up with the EXIF intact that we could see?
12-23-2012, 04:40 PM   #8
Eric Auer's Avatar
On my K-5 IIs It is Dead quiet. What lens are you using? Is it an older lens with no electronic connections?
12-23-2012, 05:54 PM   #9
VisualDarkness's Avatar
Have you put flash to on the down direction button? Merely open the flash does not trigger it like on Canikon bodies.
12-23-2012, 09:03 PM   #10
QuoteOriginally posted by alamo443 Quote
good point. now that i think about it I don't think i've ever used mine. now I gotta check to see if it works, too.
12-24-2012, 01:36 AM   #11
mcgregni's Avatar
Are you wearing a cap ? I'm serious!! I was on a work trip once where I had to wear a hard hat, and the flash didn't work - only after I tried again with the hard hat off did I realise that the front of the hat was protruding near the top of the camera and the flash was being prevented from raising fully, just by a few millimeteres, but enough for it to still think it was lowered. Did I feel dumb?? Yes I did.
02-10-2013, 11:29 AM   #12
Thanks in advance.
Alan
Hi Alan,
Yes, I have had the same problem a few weeks after receiving my brand-new K5.
After a useless firmware update I was told to send it back for repair.
The culprit was just a blown fuse. You can have a look at this thread: Re: Problem with Built-In Flash in K-5: Pentax SLR Talk Forum: Digital Photography Review
Good luck
Raphael
built-in, camera, dslr, flash, k-5, k-5 ii, k-5 iis, k5, pentax k-5
issues with K-01 built-in flash dstructor Pentax K-01 11 03-30-2013 11:52 AM
Using Built in Flash in Wireless mode with External Flash i.e AF-360fgz disco_owner Flashes, Lighting, and Studio 7 05-16-2012 07:41 AM
Built-in Flash for Pentax K-X pentax8511 Pentax K-r 7 06-30-2011 06:05 AM
K-5 built-in flash huge problem benisona Pentax K-5 13 11-06-2010 01:11 AM
flash guide updated for k-7 built-in flash mattdm Pentax News and Rumors 4 05-26-2009 06:02 PM
All times are GMT -7. The time now is 02:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
