Can it get any darker?
well...
unfortunately yes -
when I started at the dark jazz club over three years ago there were 3 mini track spot lights -
then it went down to 2 - and has been that way for years - I learnt to cope with the lighting -
then last night -
yes, you guessed it it was down to a single mini spot!
not only that the remaining light was the furthest of the three positions
from the right side of the room where most of the off stage action takes place:
ISO5000; f/3.5, 1/6 sec; 18mm +0.7 comp
(the compensation I learnt here because of the difference between my K-x which I had used for over 3 years almost weekly at this venue and my new K-5 (original) metering at the lowest light level limits)
The light level is below the metering and the AF limits of the K-5
Meter segments:
Even the stage was no longer that bright:
hats were still worn...
from where I normally shoot from it was strongly against the light -
although I could shoot from the other side - the light modelling just was not as dramatic
although I do like this shot
So basically it was a pretty daunting challenge -
but the K-5 seem to sail through it all -
any failures were due to me,
rather than the camera.
(and, no, I am not going to show you the failures
The most pleasing shots for me were those challenging off stage shots,
in comparison the on stage were like shooting fish in a barrel
(just a very dark one
