02-22-2013, 02:30 PM   #46
After hours session for 1 hour....
EXIF attached.....
that shot was setting the scene for the off stage grand piano to the left...
metering segment readings:
pretty dark ......
02-25-2013, 11:26 AM   #47
night and day difference -
some movement involved.....
03-12-2013, 12:43 PM   #48
03-15-2013, 12:34 PM   #49
dark, very dark...
EXIF attached
metering segments -
EXIF attached
EXIF attached
metering segments -
my pièce de résistance of the night
EXIF attached
metering segments:
lucky shot! - almost all movement - except for the eye?
03-19-2013, 02:51 PM   #50
Wow Vincent, you keep pushing those metering limits!
And you still get the shots. Great work.
03-19-2013, 03:13 PM   #51
Thanks rawr - always great to hear from you.
You know the old saying
familiarity breeds...
more
....confidence!
I am just more and more willing to try things out - rather than thinking/assuming "it won't work" -
the K-x and now K-5 prove (to my chagrin) that mostly the shots are possible without too much fuss.
Luckily for me I had that early "problem" of finding the K-5 didn't seem to meter as low as the K-x stopping at 1/8sec lowest limit for my settings
whereas the K-x with same setting was getting 1/4sec - fellow posters helped me discover it was a mere difference between the lowest limits in the different metering patterns
(please see: K-5 lowest metering limit? ( 1 2) ).
That's when I discovered (embarrassingly) that exposure comps still worked even below the metering limit - K-5 (and K-x) would set exposure comp from whatever it is at the lowest limit -
so my exposures pass the lowest limits have become better with the K-5 because of that gained knowledge (the K-x can do the same - it's just that I never realized it nor had the dire need).
hence "my pièce de résistance of the night" shot.....
Thanks,
03-23-2013, 09:37 AM   #52
Global Village Project
03-30-2013, 08:28 PM   #53
EXIF attached - 1/4 sec shot - hence the ghosting blur of someone walking across in the background....
metering segments -
EXIF attached - after hours, lights were turned off at the bar......
metering segments:
03-31-2013, 10:42 PM   #54
a fool's errand for April Fool's?
Last Thursday was the last gig for the band/collaborative Pure Soundz at the dark jazz venue -
EXIF attached
Really like this shot -
EXIF attached.
metering segments -
yes, I focus on the bass strings - see how much brighter it is at the center of the frame?
EXIF attached.
EXIF attached
EXIF attached.
It has always fascinated me how photos can just make out the eye lashes in the shadows -
for this shot I processed so that they are barely visible.
EXIF attached -
I have a similar shot of him earlier - I like both.
During the break they play outside -
EXIF attached -
it is actually brighter out here by street lighting than it is inside the club.
They continue to play off stage and are finding darker places!
EXIF attached -
metering segments -
phone in accompaniment?
EXIF attached
metering segments -
EXIF attached
parting shot -
next week there will be a new resident band,
the leader played frequently with Pure Soundz.....
so it's not my last gig.....
04-05-2013, 04:12 PM   #55
New band -
same dark venue -
similar off stage playing -
same faces -
practice in the dark -
04-13-2013, 09:14 AM   #56
2 gigs Thursday -
lots of the same faces at both gigs...
BIG band with.....
4 sousaphones!
that's a bass sax on the left.
next gig in next post
(I know.... you can't wait....)
04-14-2013, 09:57 PM   #57
2 gigs Thursday -
OK you can stop holding your breaths
(who speaks with a lisp?)
darker than usual
so obviously lots of off stage playing.....
that blue light is from a laptop screen - he's playing percussion from samples
very impressive/effective too. (EXIF attached)
metering segment readouts -
that's normal night street lighting out of the window -
looks like bright daylight - in comparison with the inside! (EXIF attached)
(EXIF attached)
phones providing supplemental lighting! (EXIF attached)
04-29-2013, 11:12 AM   #58
Put a little...
P Funk in your life.....
George Clinton (yes, it really is him...)
earlier same day/venue
called Red Light Cafe for a reason
red and amber gel tungsten lighting -
using tungsten WB helps - but still needed WB correction PP.
same venue main act -
difficult shot - not because of the lighting -
but just being able to get the angle -
so....
low light doesn't seem that difficult
but not easy...
04-29-2013, 02:42 PM   #59
Khashoggi's Avatar
Some lovely photo's UknownVT!
Yesterday two lovely dogs in front of my camera, normally I barely shoot animals like dogs:
04-29-2013, 03:15 PM   #60
QuoteOriginally posted by Khashoggi Quote
Difficult shots of black dogs against the light -
hope you don't mind -
my take on your second shot -
camera, compensation, dslr, exposure, k-5, k-5 ii, k-5 iis, k-x, k5, limits, meter, pentax k-5
How to use/meter Manual & M42 Lenses on all Pentax DSLRs (K-1, K-3, K-5, K-30, etc) Adam Pentax Lens Articles 313 07-08-2017 09:33 AM
K-5 ii vs K-5 iis comparison with higher sharpness in K-5 ii kataria0 Pentax K-5 62 12-22-2012 10:12 PM
K-01 worth buying if you already have K-5 in the family? dartagnon Pentax K-01 14 06-25-2012 01:25 AM
F lenses use on K-5 SEWIS Pentax K-5 14 05-25-2011 06:08 AM
PENTAX K-5 easy to spot in a crowd of K-7s (K-5 photo) Ole Pentax News and Rumors 36 09-16-2010 07:24 PM
All times are GMT -7. The time now is 04:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
