01-26-2013, 05:59 PM   #1
What is the Shutter Count of the first image of a brand new K5?
What should be the ShutterCount of the first image of a brand new K5? Any one ever checked that before?
I am having issues with SD Card that it is really hard to take it out. So I was wondering if it could be a returned item or something.
01-26-2013, 06:04 PM   #2
It varies, sometimes it's 1, sometimes it's a bit higher.
01-26-2013, 06:12 PM   #3
Thanks for the reply Adam!
The reason I asked was I just received my new K5 and the Shutter Count of the first image wsa 3.
I found a small problem with the camera that the SD Card does not eject like it does on other cameras including K100D. It was pretty hard to pull it out. That's the reason I checked the Shutter Count to see if it could be a returned item.
Not sure if a stuck SD Card is normal.
01-26-2013, 06:17 PM   #4
jatrax's Avatar
SD card is much harder to remove on K-5 than other cameras. Many posts about this when it was first introduced. I personally don't mind it at all but it is always a surprise when I use the k-x and the card comes out so easy. Particularly annoying if you have big fingers.
Anyway, it is not a problem, it is a "design feature".
01-26-2013, 06:19 PM   #5
Thanks! And it is a relief to know that it is not only on mine :-)
It is an amazing camera, so far!
01-26-2013, 10:18 PM   #6
oxidized's Avatar
Yup. Both the K-5 and K-7 have SDCards which a bit harder to remove. You get the hang of it though after some time and you get pretty good at it. My K-7 came with a shutter count of 16
01-26-2013, 10:40 PM   #7
QuoteOriginally posted by oxidized Quote
The SD card will pop up if you press it in, then slide your finger off it while you still have pressure on it. It will pop up on the spring pressure and you will soon be able to grasp it before it flies out.
Cheers
01-27-2013, 12:20 AM   #8
oxidized's Avatar
QuoteOriginally posted by deanesfield Quote
I have never ever had it "fly out". If anything I have to "dig" my fingers deep into the SDCard compartment to pull it out after it has popped out. That's what I was referring to when I said it was a little more difficult compared to other cameras.
01-27-2013, 01:03 AM   #9
This SD card issue has never been noticed by me. I press it in, the spring makes it protrude about 50% of it's length.
01-27-2013, 07:49 AM   #10
QuoteOriginally posted by Eulogy Quote
Is that on K5? It is hard enough on my K5 that I need to sit before I can take the SD Card out.
It gets locked somewhere. I don't even have to push it all the way in to get it locked.
01-27-2013, 08:09 AM   #11
Ex Finn.'s Avatar
QuoteOriginally posted by TropicalMonkey Quote
Some SD cards could be a smidgen thinner than others, my San-disk extremes have always been tight.
There must be over a dozen threads on the forums, about tight SD compartment and hard to remove cards on K7 and K5.
From the sounds of it, yours is behaving normally.
01-29-2013, 12:10 AM   #12
Yeah, on my K-5. Never had it be hard to remove really, but it did eat a Sony SD card I had at one point. Broke the plastic spacers between contacts...
01-29-2013, 10:54 AM   #13
reeftool's Avatar
When I first bought my K5, I popped in a card I had been using on my K10D and it started numbering the files in sequence to what was already on it. A program like Photo Me will show the real shutter count. A few shots would be normal. I think that occasionally, they fire off a few test shots. The cards are a tight fit but these bodies are also smaller than K10D/20D so the reason is obvious. I've become pretty good at swapping cards, even with my big hands.
01-30-2013, 09:17 AM   #14
I received my K-5 (first model) factory sealed and it the first picture that I took increased the shutter count to 1 :-)
Today I got my K-5 IIs and it seems that someone used it already, because it has a shutter count >200. Although it is not correct (IMHO) to sell a camera like this as new, I will keep it if I donīt find problems ...
So, I guess a new K-5 II/IIs should have a shutter count of 0 (or 1 after taking the first picture).
Best wishes,
Klaus
01-30-2013, 01:48 PM   #15
jatrax's Avatar
QuoteOriginally posted by kdre Quote
I received my K-5 (first model) factory sealed and it the first picture that I took increased the shutter count to 1 :-) Today I got my K-5 IIs and it seems that someone used it already, because it has a shutter count >200. Although it is not correct (IMHO) to sell a camera like this as new, I will keep it if I donīt find problems ...
Not necessarily. It was reported that on the K-5 Pentax re-set the shutter count to zero after testing, but on earlier cameras it was common for an brand new in the box camera to have a good number of actuations presumably for testing. Possibly the K-5IIs is not being re-set before leaving the factory.
There were a few threads on this awhile back but my quick search could not find the one I wanted.
Where did you purchase it?
brand, camera, dslr, image, k-5, k-5 ii, k-5 iis, k5, pentax k-5, shutter count
The tale of my first 24 Hours of K5 Ownership... Origineelreclamebord Pentax K-5 12 07-04-2012 04:05 AM
What is your K5 shutter count ? jpzk Pentax K-5 25 05-29-2012 08:26 PM
How quiet is the K-01' shutter? Can we turn off the sound of the AF confirmation? powP0Wpow Pentax K-01 9 03-08-2012 03:19 AM
How to find the shutter count of a K10D? Rnovo Pentax DSLR Discussion 7 11-24-2010 08:02 PM
What the heck is that an image of??? alehel Photographic Technique 6 05-04-2009 02:54 PM
All times are GMT -7. The time now is 12:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
