03-27-2013, 03:19 PM   #106
MarkJerling's Avatar
QuoteOriginally posted by p38arover Quote
Has anyone had any problems with the firmware download?
I have tried several downloads from pentax.jp and extracting them to a couple of different SD cards as well as extracting to the HDD and copying them to the SD cards.
Everytime I try to load the new firmware, I get an Update File is Damaged message from the camera, after one attempt, Ii had a heart stopper - the camera rear display would not work and nothing I did would restore it - until I removed the battery and let it sit for a few minutes before reinserting the battery.
Hi
What could be happening is that your first download of the update file was corrupted somewhere in the path between the Pentax server and your PC. Now, when you download the file again, your service provider may be sending you the same file, rather than requesting the file from the Pentax server as a fresh download. Try downloading the file from a separate PC, on a separate network. Preferably, download the file on a wired network, rather than a wireless network. Built in file download protocols prevents this sort of thing from happening 9.99999/10.
When you load the files to an SD card, make sure the SD card is empty and that you're not placing the file in a folder on the card.
Remember all the usual advice about fully charge battery, etc, when loading the new update file.
I've successfully updated twice now - no problem. This must be quite frustrating for you. Good luck!
Regards,
Mark
03-27-2013, 05:48 PM   #107
p38arover's Avatar
Just download the correct file from Pentax JP or Pentax USA, making sure you choose the right download for your operating system (and camera!) and do the upgrade by the book (from the Pentax USA site):
Yep. I downloaded from Pentax Japan. I'll try the US site.
QuoteOriginally posted by MarkJerling Quote
Hi
Thanks for the suggestions. I'm using my desktop (wired, not wireless). I had placed the files in the root directory of the freshly formatted SD card, had a fully charged battery, etc.
I didn't have any problems when I updated my K-7 or Q.
I'll try again.
03-27-2013, 06:14 PM   #108
p38arover's Avatar
A fresh download, this time from the USA, seems to have worked.
03-29-2013, 04:57 PM   #109
Great!!
03-29-2013, 05:53 PM   #110
p38arover's Avatar
I'm about to go out and test it (side by side with my K-7).
camera, dslr, firmware update k-5, k-5, k-5 ii, k-5 iis, k5, pentax k-5, v1.14, version
New firmware: v1.13 for K-5/645D, v.1.12 for K-7/K-r, v1.03 for K-x Adam Pentax News and Rumors 71 05-15-2012 01:42 PM
Pentax K-5 v1.10 Firmware magnosantos Pentax K-5 128 01-21-2012 02:41 AM
Comparison of K-5 low light focus accuracy with v1.01 and v1.03 of firmware tram57 Pentax K-5 3 03-20-2011 08:13 PM
New Firmware V1.03 for K-5! HermanLee Pentax News and Rumors 30 03-16-2011 10:50 AM
Unable to install firmware update v1.02 on K-x califgrll Pentax DSLR Discussion 10 01-15-2011 09:59 AM
All times are GMT -7. The time now is 06:00 PM. | See also: NikonForums.com, part of our network of photo forums!
