Hi there,
I am using a Metz 50 AF-1 flash with my K5 and the 16-55 DA*, I got over exposure problem with it. Whenever I bounce the flash off the ceiling at an angle I got 2-3 stops over, but it is fine when tilt 90 degree up, also fine in direct flash, this happen in all auto modes, I've to re-shoot and override via compensation to get it right, I got this problem with off brand flash as well. As far as I experienced I find Pentax DSLR is quite weak at the flash control, easy to get over exposure at close range. The camera and the Lens have just been repaired by Pentax for AF problem, so I assume everything checked out, any comment ?
Update :
I just read a post on Dpreview about the same problem, it is confirmed a bug on the K5 causing this, but I already have the latest firmware on both unit, V1.14 on K5 and V3 on the Metz !
Reason: Update
