02-19-2013, 08:39 AM   #1
using Flash with auto iso.
Will the k5iis automatically bring down the iso to compensate for the Flash in av mode?
02-19-2013, 09:17 AM   #2
QuoteOriginally posted by lightbulb Quote
lightbulb,
If it is anything like the k-r then it won't do exactly what you want it to do. I find that in Aperture priority mode (assuming you are using P-TTL here) the camera tends to push the shutter speed down (1/10 to 1/60) instead of pushing the ISO up. So you don't get consistent results picture to picture. Your first shot might be 1/30 at ISO 200 and the next might be 1/100 at ISO 800. So you end up getting a weird mix of ambient / flash from one pic to the next and sometimes motion trails if it pushes the shutter speed too low. I would recommend that you pick an ISO that you are happy with instead of using auto mode, at least if you want to get more consistent results with your flash.
02-19-2013, 11:26 AM   #3
The camera will bring the ISO down to compensate for ambient lighting without the flash (i.e. a dark room will result in the camera using close to your maximum specified ISO, e.g. ISO6400/12800) and then the flash will adjust it's output for the ISO.
02-19-2013, 05:06 PM   #4
Ok Thanks guys; )
camera, dslr, flash, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Problem with my k-x using anything but auto. Everythings tinted blue (with pics) noah240t Troubleshooting and Beginner Help 4 01-13-2013 05:12 PM
Strange auto-ISO behavior with flash ? madbrain Pentax K-30 & K-50 37 12-30-2012 06:58 PM
K5 Flash and Auto ISO charleychen Pentax K-5 12 10-10-2011 03:56 AM
Auto ISO with ext flash defaults to high? wutsurstyle Pentax K-5 14 07-29-2011 11:41 AM
Using old Auto-Flash with K100d Papersniper Troubleshooting and Beginner Help 20 02-28-2008 08:34 AM
All times are GMT -7. The time now is 08:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
