02-24-2013, 05:47 AM   #1
old4570's Avatar
K5 Max size for SD card ?
Just wondering , what is the max size for a SD card in the K5 ..
32GB / 64GB / 128GB / 256GB
02-24-2013, 06:19 AM   #2
boriscleto's Avatar
With the original firmware 32GB. Firmware 1.02 enabled SDXC so theoretically up to 2TB, but of course no one makes one bigger than 256GB yet.
02-24-2013, 06:51 AM   #3
Banned
But also consider... It is usually a bit more than just what the camera will be able to handle.
Consider any computer that the images will eventually be downloaded to. If one is stuck downloading to a physical platter hard drive of any size (even above one terabyte), that in downloading either the 256 or even the 128 you'll actually cause issues with the hard drive. Also imagine trying to defrag a hard drive after all of that data goes onto it. Plus even if one happens to have a SSD drive; most only come in either a 480gb or typically (for this point in time) 600gb capacities.
02-24-2013, 03:55 PM   #4
old4570's Avatar
Thats ok
QuoteOriginally posted by Medium FormatPro Quote
Thats ok , my computer will handle it just fine ... 256Gig even , but I was thinking 64Gig for a back up SD card since they are cheap enough ..
I will have to check what firmware version is on the K5 ...
Oh , I was not planning to ever fill a SD card ( the best laid plans ) , just wanted to know what the camera and my wallet can handle .. Thank you .
03-02-2013, 01:01 PM   #5
tabl10s's Avatar
Couldn't do 64g Until 1.13.
03-02-2013, 02:55 PM   #6
boriscleto's Avatar
QuoteOriginally posted by tabl10s Quote
1.02 added SDXC, 1.13 fixed a specific problem with SDXC...
03-02-2013, 03:38 PM   #7
bullitt_60's Avatar
I encourage you not to only get one card for 'redundancy' reasons. If you have ever had a card corrupted, you know what I mean... not only do you lose the data on the card, you are done shooting until you can replace it. I always have 2 (now 3) 32GB cards with me.
03-02-2013, 04:21 PM   #8
old4570's Avatar
Ordered a 2nd card for the camera ( back up card )
I can get almost 100 pictures on a 1GB card ( all I had at the time ) now I will have 2 x 16GB , so safely over 1000 pictures per card .. Though a larger card ( 64gb ) will be purchased ..
I updated to the latest firmware ... ( 1.14 )
04-23-2014, 10:50 AM   #9
QuoteOriginally posted by boriscleto Quote
Is the firmware issue why my 10 month old K5 will not keep the formatting on the two brand new 64gb sd cards I just bought?
04-24-2014, 11:17 AM   #10
Insanely humble
savoche's Avatar
QuoteOriginally posted by bullitt_60 Quote
I have a bunch of 16GB cards for just that reason. They can hold about 500 raw images, or 400 raw+JPEG, and that is already more than I'd like to lose in one go... And still sufficient to not having to change cards all the time.
Of course, if you are in the habit of taking long series of pictures every time you push the shutter button then forget what I just said
05-28-2014, 09:48 AM   #11
Scootatheschool1990's Avatar
Would this be a good purchase? would it work for my k5?
http://www.ebay.com/itm/SANDISK-ULTRA-SDXC-CLASS-10-128GB-30MB-SEC-UHS-I-SD-...item4d17e18392
05-28-2014, 10:24 AM   #12
I would not buy such a large card - they do fail and you could lose too much data.
After hearing from a lot of folks on this forum I would now use nothing larger that a 32 - and have several on hand at any time and also use a card reader to download from because the camera jacks wear out - like mine has, when you keep plugging in the chord!
05-28-2014, 10:53 AM   #13
Insanely humble
savoche's Avatar
I still stick to 16 GB cards. There's room for 500 raw images on one of those, which is already more than I care to lose in one go. The thought of 4000 images (or goodness knows how many jpegs!) in one card failure makes me feel ill...
Oh, it should work. But I would never do it.
06-04-2014, 08:16 AM   #14
QuoteOriginally posted by jzimages Quote
Awesome! Thanks for your time guys!
06-06-2014, 05:53 PM   #15
QuoteOriginally posted by savoche Quote
But a 16GB card is only 30 minutes of max. quality video on K-5... so it's only big enough in practice for those who stick to photos or low quality video. I always carry a couple of 32 GB cards with me, just in case.
camera, card, dslr, k-5, k-5 ii, k-5 iis, k5, max, pentax k-5, sd, sd card, size
K5 Firmware SD card size FenderGirl Troubleshooting and Beginner Help 3 12-21-2012 09:47 AM
WG 1 mini sd card max drhugh Pentax Compact Cameras 3 07-25-2012 07:58 PM
Max card size for DS? PeterAM Pentax DSLR Discussion 2 02-26-2012 03:04 PM
Max size for an SD card in K10d russblack Pentax DSLR Discussion 1 03-11-2008 07:47 PM
Max size sd card for k100d/k10d ? shane Pentax DSLR Discussion 17 09-18-2007 01:12 AM
All times are GMT -7. The time now is 01:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
