02-28-2014, 09:01 PM   #91
THoog's Avatar
QuoteOriginally posted by totsmuyco Quote
Can you guys help me out? Can I use my yongnuo 560II on my K-5II using manual mode "M" instead of "X"? I used it 2 weeks ago but I found out that my flash misfired after some shots despite using a 1/160peed. I started using the "X" setting and at times the flash misfired. I removed the flash and mounted it again and the flash would start working. Is there something wrong with my camera? Did I burn my flash connections by using "M" instead of "X". Thanks
Using 'M' instead of 'X' wouldn't damage the flash. See this thread for similar problems with the earlier versions of the YN-560.
https://www.pentaxforums.com/forums/115-pentax-k-5/162331-mounted-yn-560-flash-problem.html
03-01-2014, 04:39 AM   #92
Thank you. I've read the thread and I'm at peace that neither my camera or my flash was damaged. However, I don't think I can do what they did. Thanks again
03-10-2014, 04:51 AM   #93
Basic info needed
Hi All,
I know I'm going to sound stupid but will the YN-560 III (or the YN-560 II) just fit straight onto my Pentax K-20D?
Having done research around there are dedicated pentax flashes and these type that use the generic hotshoe. What difference does this make?
I know what I'm doing with flashes so I'm not put off by it being manual, but just can't seem to find anywhere any info on if this gun will talk to the camera or not, and what the benefit of getting a dedicated (and more expensive) Pentax flashgun would be.
Any info would be great, thanks
03-10-2014, 01:01 PM   #94
Class A's Avatar
QuoteOriginally posted by pauldiebel Quote
Yes, it will.
Dedicated flashes support P-TTL (automatic exposure) and potentially extras like second-curtain sync and/or HSS (high speed sync). You may also get a display about how far the flash will reach given the current settings and the flash's zoom will change according to changes to a zoom lens.
The YN60-II(I) is not available with Pentax dedication so you can only set the power manually and fire shots.
05-27-2014, 11:11 AM   #95
Class A's Avatar
First images and descriptions of the YN560-TX are appearing.
No indication of price or availability yet, but at least there is more than a rumour now.
The trigger appears to be much less versatile than the Cactus V6 but anyone who owns a couple of YN-560 III should be excited.
09-24-2014, 01:27 AM   #96
Hello guys, i dont know much about triggers and recievers but i do have a 560iii i want to fire it off camera what do i buy? i read on this thread that the RF603C II C1 is the best ? since i will also like to use the cable trigger as well, pls help
09-24-2014, 12:23 PM   #97
Class A's Avatar
QuoteOriginally posted by AyiteyHammond Quote
If I were you, I'd get the YN560-TX trigger since it allows one to remote control the power level as well.
04-08-2015, 09:19 AM   #98
LeonPajuelo's Avatar
Hi everyone!
I have got a K-500. Is there any problem, issue, disadvantage using the 560III? Is there any significant difference between 560ii and iii? Talking about use them on a K-500.
Thanks for your replies and advices.
Sorry about my poor English.
04-08-2015, 09:28 AM - 1 Like   #99
the only difference between them is that the iii has an integrated RF receiver....
this is very useful if you want to use the flash off camera...
my recommendation is to buy the iii, you'll definitely want to try off camera flash some time.
cactus, camera, control, dslr, flash, flashes, iii, k-5, k-5 ii, k-5 iis, k5, onboard, pentax k-5, photo, yn-560, yongnuo, yongnuo yn-560 iii
mounted YN-560 flash problem tx0h Pentax K-5 42 09-22-2017 09:57 AM
Yongnuo YN-560 II now avaiable usrbrv8 Flashes, Lighting, and Studio 60 01-25-2014 07:08 PM
yongnuo YN-560 flash for k-x mtkang Flashes, Lighting, and Studio 25 01-03-2012 11:22 AM
Is YN 560 worth buying? wildweasel Pentax Camera and Field Accessories 10 09-18-2011 07:53 AM
$2.75 omni-bounce-like Flash Diffuser for YN-560 geekette Flashes, Lighting, and Studio 8 06-12-2011 10:24 PM
All times are GMT -7. The time now is 11:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
