02-27-2013, 11:49 PM   #1
Trying to set the fine adjustment for different lenses and failing
Right now I am working on 2 lenses on the K-5 IIs
Sigma 18-50 f2.8
Sigma 50-500
The sigma 18-50 is almost bang on the 50-500 front focuses a bit. I set the adjustment to "Apply One" but when I switch lenses whatever adjustment is still in effect. The manual says saves adjustment value for each lens type. Does this mean they are the same lens type therefore cannot have different adjustments?
02-28-2013, 02:33 AM   #2
bxf
bxf's Avatar
My Sigma 50mm f1.4 is seen as something else by the software- It's possible that both of your lnses are coming up with the same ID, and hence not being differentiated from each other.
02-28-2013, 02:41 AM   #3
The camera 'reads' the lens signature from a microchip in the lens. Every modern Pentax lens has a unique signature, but Sigma it seems share a number of 'signatures' across their lens range, so two lenses, although optically different, will look identical to the camera.
02-28-2013, 06:12 AM   #4
Hi!
Try to RESET ALL settings, remove battery, wait 10 seconds or so, insert battery, and try again.
02-28-2013, 06:38 PM   #5
BPT
QuoteOriginally posted by bxf Quote
These are older lenses (screw drive 6ish years old) so perhaps they were not worried about uniquely identifying them
QuoteOriginally posted by JohnX Quote
Well that will be a bit inconvienient for me, at least the lens isnt badly front focusing but shifting that way
QuoteOriginally posted by zenn Quote
Hi!
Didnt help, but thanks for the suggestion
adjustment, camera, dslr, k-5, k-5 ii, k-5 iis, k5, lens, lenses, pentax k-5, sigma, type
18-135mm: How to AF Fine Adjustment over the full zoom range? strahl Pentax K-30 & K-50 4 10-06-2012 06:31 AM
K-r is failing to communicate with Sigma lenses. Manufacturers and shops are stumped. alasdair03 Troubleshooting and Beginner Help 9 03-21-2012 07:56 AM
K-5 AF fine adjustment - does it work for non Pentax lenses? Christine Tham Pentax K-5 & K-5 II 30 12-28-2011 01:35 PM
Just did AF Fine Adjustment - all my lenses are off?! HenrikDK Pentax K-5 & K-5 II 30 07-27-2011 06:55 PM
Trying to set the lens mm for shake reduction gary1952 Pentax DSLR Discussion 26 07-14-2010 02:32 PM
All times are GMT -7. The time now is 11:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
