Originally posted by GlennG It was only February 2013 that I bought my used K-5 and I swear that at that time the only problem that I knew to look out for was the sensor stain.
Well, sensor stains had been long been an issue of the past already at that time, along with
many other issues you apparently missed.
Some of the issues I referenced above still exists today, though. The flash overexposure bug has never been fully addressed (apparently a hardware limitation is at play) and the K-5's AF low-light issues and its dependence on colour temperature have long been known (since 2011). Some users, of course, claimed their K-5 doesn't have the issue and that most people cannot use their cameras correctly, but if you had read
Falk Lumo's report you would have known that it is more likely that the users "without the problem" just didn't know how to provoke it.
All good with the K-5 II, however, AFAIC. It believe it still has the P-TTL flash overexposure issue, but I personally don't care because I'm using external flashes in manual setting only.
P.S.: If you have AF issues in normal daylight then you may want to consider reading my
AF adjustment hints. Be careful, though, as inadequate changes to the AF adjustment values can make things worse. You need to set aside a lot of time, if you want to do this right.
