Show Printable Version 6 Likes Search this Thread
03-11-2013, 05:27 PM   #1
Driline's Avatar
How many will admit to using the "GREEN" Mode
I will admit that sometimes when I need a fast picture right away that I will in fact dial up the green mode and shoot away. More often in low light than any other situation.
03-11-2013, 05:34 PM   #2
Lurch's Avatar
To be honest, the only time my K5 goes into Auto is when my wife uses it.
Other than that, it pretty much "lives* in Av unless I can't quite get what I'm chasing.
03-11-2013, 05:36 PM   #3
monochrome's Avatar
P is the new Green
03-11-2013, 05:39 PM   #4
GabrielFFontes's Avatar
QuoteOriginally posted by Driline Quote
To be fair, never even touched it. Ever, really.
Using TAv and Av is just as fast as green mode.
In good light, just set your aperture and check if you need any EV compensation...
In low light, set your aperture and shutter speed and let the camera choose the ISO for you! Its just perfect.
03-11-2013, 05:40 PM - 3 Likes   #5
boriscleto's Avatar
P is the new Green
P stands for "Professional" - Ken Rockwell
03-11-2013, 05:42 PM   #6
monochrome's Avatar
QuoteOriginally posted by boriscleto Quote
Oh thank you! Thank you. You finally broke the code for me!
03-11-2013, 06:07 PM   #7
causey's Avatar
Only Av and M for me. I use P on point and shoots.
03-11-2013, 06:16 PM   #8
paulh's Avatar
I think I used the green mode for a couple days when I first got my *istD. Then I got a copy of "Understanding Exposure", and it's been Av or M ever since.
03-11-2013, 06:22 PM   #9
maxfield_photo's Avatar
It goes against my religious beliefs. I am an Orthodox Manual shooter.
03-11-2013, 06:27 PM   #10
ivanvernon's Avatar
I shoot in manual mode with M lenses and Helios. I sometimes shoot a scene in Green mode, and check the settings, then go to manual mode and adjust aperture and shutter speed to get results closer to my idea of what I am trying to achieve. It is like: Camera, what can you do, now let me do it better with Green mode as a starting point. I do use autofocus with lens that offer it, but sometimes fine tune the focus. I use split prism Katzeye to focus with non-AF lens, meaning I use my non-AF lens almost entirely on my K-20, and AF lens of K-7.
03-11-2013, 06:31 PM   #11
jac
I've never touched the l'il devil on the ist*DS, 20D or the K5. If blind-sided on the street with a question about what it does, I'd really have to think about it. TAv, AV or M seem to work although I always forget to change some button, dial or fn setting. As a member commented in another post today, I just keep moving those little gizmos 'till I get something right.
03-11-2013, 06:36 PM   #12
Ya, I'll admit it. When my daughter is doing something cute and I need to run to the camera cabinet (yes cabinet, Hi, my name's Rod and I'm a camera addict), by the time I get the correct camera there's just time to grab it, hit green mode, and shoot. If it makes me sound a little less amateurish I know what each camera will do on green mode and select the correct camera for the situation . In any other situation I'll use Av or M (M stands for manly).
03-11-2013, 06:38 PM - 1 Like   #13
NitroDC's Avatar
The closest I come to green mode is in P for snapshots. If I am composing and thinking about a shot I always use either Av/Tv or M. I've actually never used the green mode now that I think about it, not even when I was a beginner with my K100D Super.
03-11-2013, 07:04 PM   #14
TheOtherRob's Avatar
I don't use Green any more, but that's not because I don't think its useful. It just that some of the other auto modes are as good and will produce raw files if desired.
I used green mode a lot when I first bought my K-x... and have the lovely, glowey cheesy but generally happy JPEGs to prove it. I love 'em because they are the shots that introduced me to the fun of photography before I really cared about technique. But I am glad for Green Mode and the shots I took with it because they are the shots I would never have had without it. I am not sure that makes sense.
After I grew curious with what lay beyond green I muddled around a bit and then bought Understanding Exposure and became a M mode fanatic for a while. It was great for learning what the big three settings did, but I missed a lot of shots because of it. Some of the joy and spontenaity of just taking photos was lost as well. These days, I shoot M when I really want a specific artistic result or when I am using my K1000 for kicks.
But as for the original poster's question... I don't use Green any more. Ever. But that's not because I am a snob when it comes to trusting the camera's capabilities in situations that are just too spontaneous or evolving too fast for me to manually respond to. I am still far too short in technical skill to be able to safely rely on my own settings in a time critical situation (though I do try, for practice' sake). I would probably still use Green for just walking around if it wasn't for one little factor; I usually like a RAW image to muck around with at the end of the day. In fact, due to the nature of snaps of opportunty I especially want maximum flexibility when I get home, so RAW is essential for me.
My current "Green" equivelant for when I am just walking around and have no idea what will be in the next frame is TAv with spot metering and centred autofocus. I feel that the biggest strength of a modern camera is ISO range, so I let the camera do the work in picking ISO while I set shutter and aperture to the general conditions (usually sharpest aperture for the lens and 1/125).
Having said that, I would estimate that well over half of my shots are Av when I have some idea of what is going to be in frame next. Which is most of the time. Thus, while I don't do Green any more, it's not because I think it is cheating. There is nothing wrong with trusting your camera's capabilities in a tight spot when it can respond more accurately and quickly than you. I just don't use Green because some of the other auto modes do just as well and prodice raw files if desired.
03-11-2013, 07:13 PM   #15
twitch's Avatar
Green mode switches off lens corrections and RAW, and then switches on all 11 AF points so it can guess focus, 3 reasons I don't like using it.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, mode, pentax k-5
Playback mode - "jumping" picture when using the rear dial. jpzk Troubleshooting and Beginner Help 8 10-22-2012 05:38 PM
Where to get start when it comes to learning "the how" jtkratzer Troubleshooting and Beginner Help 44 07-22-2012 04:43 PM
How does the "Program" mode works? ismaelg Film SLRs and Compact Film Cameras 5 07-09-2009 06:43 AM
How to ISO in "P" Mode Stratario Pentax DSLR Discussion 6 05-12-2009 05:43 PM
How to tell how many "clicks" my DS has clicked? mediaslinky Pentax DSLR Discussion 8 04-13-2007 03:00 PM
All times are GMT -7. The time now is 03:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
