03-15-2013, 03:43 PM   #1
fs999's Avatar
New bug or new limitation ?
I discovered this week that when using my Danubia PK/A-R extension tubes there is not aperture indication with A and DA lenses (F-- viewfinder and top screen), except in Live View !
There I can change the aperture with the wheel.
And the aperture is saved when I go back to viewfinder and shoot, but I cannot change it...
These tubes have only six contacts. Focal data is not transmitted...
03-15-2013, 05:44 PM   #2
RonHendriks1966's Avatar
No idea, I have a tube with a full set off contacts, only no AF.
03-15-2013, 06:58 PM - 3 Likes   #3
Is the surface of the tube, where it is mated with the camera, chrome (bare metal) or anodized (black)?
If it is anodized, you need to sand or scrape the insulating black material down to bare metal. See the arrow in photo below as where to sand/scrape:
03-16-2013, 12:03 PM   #4
fs999's Avatar
Thank you it solved my problem !
But how is it possible that it worked in Live View ?
03-16-2013, 12:10 PM   #5
QuoteOriginally posted by fs999 Quote
My guess is that it didn't really -- sometimes live view will display a "phantom" aperture instead of nothing, but I'm guess you really wouldn't have been able to stop down mechanically using the wheels. Trust the non-live view "F--"
03-16-2013, 12:14 PM   #6
fs999's Avatar
No I could change it in Live View and it stopped down correctly even in non-Live View !
I could open to 1.7 with the A 50mm 1.7 and to 2.8 with the DA 40mm XS !
03-16-2013, 12:31 PM   #7
Well, it is open by default, so the question is could you close it down to f/11 or whatever?
03-16-2013, 12:58 PM   #8
fs999's Avatar
Yes, even to F22 and I verified it.
03-16-2013, 02:28 PM   #9
Huh. Well, behavior is notably quirky with most extension tubes with contacts. Some lenses work, some need modification of the tubes, etc.
07-07-2014, 06:44 AM   #10
Class A's Avatar
QuoteOriginally posted by SOldBear Quote
Thanks a lot!
This worked for me but I noticed that one only actually needs to clear a rather small area (pretty much where your arrowhead points to) for the seventh contact on the camera to make contact.
Strangely, my camera always gives me the option of f/1.2-f/22 independently of the lens I mount. Do you experience the same?
The contacts do not appear to transmit the correct min/max aperture encoding. However, stopping down the lens works and this is the most important thing.
aperture, camera, change, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, tubes, viewfinder
K-30 Metering Bug in the new Firmware??? drivingback Pentax K-30 & K-50 10 11-18-2012 11:31 AM
New Camera or new lens??? Mortimer Pentax SLR Lens Discussion 23 04-25-2012 01:38 PM
New camera or new lens dougfrey Pentax DSLR Discussion 39 11-20-2011 04:12 PM
New lens or new body? Clacaf Pentax DSLR Discussion 21 07-28-2011 08:38 AM
Hi all :) New to the forum (or not so new) kneonx Welcomes and Introductions 2 06-25-2011 04:17 PM
All times are GMT -7. The time now is 12:36 PM. | See also: NikonForums.com, part of our network of photo forums!
