Originally posted by SOldBear I think Metz AF58-1 does not have auto thyristor mode.
This is quoted from 58 AF-1 Manual
5.5 Automatic flash mode
In the automatic flash mode A, the flash unit sensor
measures the light that
reflects back from the subject. The sensor
has a coverage of about 25°, and
only measures the light for the time a flash is fired by the mecablitz. The flash is
cut off as soon as sufficient light has been emitted for correct exposure. The sensor
of the mecablitz has to be directed at the subject.
The maximum range is shown on the LC display. The shortest shot distance is
approximately 10% of the maximum distance range. The subject should be located within the middle third of the distance range shown on the LC display to
allow the electronic system sufficient leeway for compensation.
Setting procedure:
• Press the „Mode“ button until „Mode“ flashes on the LC display.
TTL TTL
☞98
• Set the flash mode using the UP and DOWN keys. The flash mode
selected is then highlighted. The setting takes effect immediately.
• Press the „Return“ button to change the LC display back to the normal
view. If the „Return“ button is not pressed, the display will change back to
the normal view after about 5 seconds.
If the shot was properly lit, the correct exposure indication
will flash „OK“ for
about 3 seconds (see 14).
