03-22-2013, 06:00 AM   #1
Removing K5 D-rings?
Thinking of trying a Black Rapid but as I wouldnt be using the D-rings, I was wondering if they can be removed?
Last thing I want to do is damage or scratch anything!
03-22-2013, 06:10 AM   #2
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by JayX2A Quote
I guess stay away from the oxyacetylene torch then for burning them off.
Seriously I'm not sure how to remove them, someone will be along in a minute with the right answer.
03-22-2013, 06:11 AM   #3
QuoteOriginally posted by kerrowdown Quote
Lol - extreme measures?!
03-22-2013, 06:30 AM   #4
TER-OR's Avatar
I don't use the neck strap anymore, but just left the D-rings on. Probably for the same reasons you see, they're tight little things. I did add S-biners to the kit strap so I can use it if I want, but I like the sling strap attaching to the tripod mount better.
03-22-2013, 06:35 AM   #5
Do you mean the triangular stainless steel rings that come with the K-5 for attachment of the neck strap? These come off and on easily. If you use your fingernail to spread the tip apart instead of a metal tool you won't scratch anything.
Or do you mean the connector on the BlackRapid? You would have to cut that off with a hacksaw, or unstitch the BlackRapid strap, remove the connector, and then restitch.
Or do you mean something else?
Russ
03-22-2013, 06:37 AM   #6
So I have established they do not come off easily!?
03-22-2013, 06:42 AM   #7
Yeah the triangle rings on the k5 - nothing on black rapid.
So finger nails is the answer! Not home for couple of days so just wanted some tips before I got back to see how easy it is.
03-22-2013, 08:43 AM   #8
Pauld's Avatar
They are a bitch to get off but it can be done. I would recommend using a micro flat head screwdriver to pry it open and then feed it through the ring on the camera. I couldn't get it to open with my fingernails and with my big fingers the rings are pretty tiny to operate with.
03-22-2013, 11:19 AM   #9
stormtech's Avatar
They come off easily enough - no different than working with a key ring.
But, I must confess - my Fuji X10 came with a little plastic tool for just this reason - works great!
03-22-2013, 11:31 AM   #10
Well I did a quick test an came off easily enough!
Now got to decide if I want to go black rapid or optech. Slightly concerned as have read some reports that the black rapid clip can scratch the bottom of the camera. I guess that depends how you store it.
03-22-2013, 11:43 AM   #11
stormtech's Avatar
There was no choice for me as I have an arca-swiss plate on my camera all the time as I use a tripod most of the time. And more of a personal opinion, but I trust the strap lugs more than the tripod mount - the tripod mount is meant to be used with the camera in a vertical position - not upside down hanging from it.......
03-22-2013, 12:46 PM   #12
Ben_Edict's Avatar
QuoteOriginally posted by stormtech Quote
I have the Manfrotto hexagons attached to all the camera bodies and the bigger lenses all the time. I would never start swapping those with a strap, that's screwed into the tripod socket, too. Not an option for tripod users...
Ben
11-22-2013, 11:29 PM   #13
Old thread I know, but why would you want to remove the clips as they are not in the way at all. I have a Black Rapid too, and currently looking at options to use still use the original strap especially when using a tripod.
11-22-2013, 11:46 PM   #14
wizofoz's Avatar
I removed the d-rings from my K-5 and K-3. I don't like neck straps, so they were just going to cause wear. They are fiddly, but not too difficult to remove.
11-23-2013, 01:37 AM   #15
Heie's Avatar
I'm a big believer in the Op/Tech system. I love that they are interchangeable because all the quick disconnects are the same and don't take up the tripod mount (the thought of it unknowingly wiggling loose and then dropping to the ground scares the crap out of me). At first I was concerned with the Op/Tech because it looks weak, but I promise you those fears are gone now!
Top: Pentax K-30 + DA*16-50 on Op/Tech Backpack/Reporter
Bottom: Pentax K-5 + Grip + DA* 60-250 on Op/Tech Sling Strap.
And the best part is that they are cheap!
-Heie
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
For Sale - Sold: K5, D-BG4 Grip, 'L' Bracket trublubiker Sold Items 6 10-19-2012 11:23 PM
Removing the AA filter from the K5 pinholecam Pentax K-5 & K-5 II 5 09-05-2012 05:04 PM
So happy with my K5!!! :-D vimeto Pentax K-5 & K-5 II 20 02-23-2012 04:14 AM
k5 D-BG4 problem live view sifun Pentax Camera and Field Accessories 2 10-23-2011 05:17 AM
K5 et ses défauts thierryk5 Pentax K-5 & K-5 II 135 04-02-2011 12:42 AM
All times are GMT -7. The time now is 11:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
