03-27-2013, 07:51 PM   #1
K5 down res - what does the camera do?
The K5 has some resolution options that are less than 16 MP. Do you know what the camera does to obtain a file with 10 MP, or 6 MP? Does it turn off some pixels and use only the remainder? Or, does it take all 16 MP, and then "combine" some of them? Do you know? Also, if I set the K5 to 6 MP, how would the 6 MP IQ compare to the 6 MP IQ of my old K100dS?
Additional thought, since I have both cameras, I guess I could do that test myself - take some pictures and pixel peep. How would you do it? I'm thinking static subject, tripod, same lens, same conditions, etc. But the cameras are not the same, processors are not the same.
03-27-2013, 07:57 PM   #2
It uses all of the pixels and scales the image. The algorithm that the camera uses is probably not going to be as good as the ones available in photoshop, as there are many types of scaling/interpolation algorithms, all of which are good at different things.
03-28-2013, 06:59 AM   #3
Thanks, Adam. Pretty much as I'd thought. I appreciate the reply and info. Maybe as I get time I'll do the comparisons I mentioned.
Glenn
camera, cameras, dslr, iq, k-5, k-5 ii, k-5 iis, k5, mp, pentax k-5
What does 'in camera' HDR do? slackercruster Pentax DSLR Discussion 8 04-15-2012 06:38 PM
The pins on the body, what does each do? Nass Pentax DSLR Discussion 2 09-16-2011 05:25 AM
what does the slide copier do for the bellows? SFEAR Pentax Camera and Field Accessories 7 05-18-2011 01:52 PM
What exactly does IS in the body do? justtakingpics Pentax DSLR Discussion 13 06-23-2010 12:33 AM
What does the repair center do? jrforman Pentax SLR Lens Discussion 5 05-12-2008 08:22 PM
All times are GMT -7. The time now is 05:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
