04-01-2013, 12:35 AM   #1
focus peaking in K-5 II/IIs (?)
It's a definite feature missing out on the "flagship" cameras... Am not sure if the Q gained it through a firmware update, but can it not be incorporated into the more powerful DSLRs? It's a real bummer that the lower-end model has it and the higher-end one doesn't, as it is much helpful for those using LV and long lenses.I wear eyeglasses and manual focusing even with the K-5's modest-sized VF is difficult.
So is it really impossible for the K-5 (or for marketing's sake, the II/IIs) to get it?
04-01-2013, 01:52 AM   #2
Impossible? No. Practical? Not really. Fret not, I'm sure that Pentax will launch the new APS-C Camera in years end, no doubt with subtle improvements across the board and some minor feature implementations.
My guess for changes:
24MP Toshiba Sensor(Same as D7100/D5200/D3200) - Probably lacking an AA filter, or having an "S" variant.
Improved Weather Resistance(Perhaps combined ports for more things, reduced the number of seals required)
Faster, More Responsive AF with better low light than K-5II/s perhaps.(As well as an AF-C overhaul?)
Focus Peaking
1080 24/25/30/(60?) Video
More Cache Memory, allowing for longer bursts, and perhaps freeing you to view photos in less time than 30 seconds after filling the buffer with RAW?
More "Creative Filters"(Or as I call them, wasted development resources)
Wishes:
A brand new lens release button, that doesn't fall off!
De-Crippled K Mount
Support to disable SDM on lenses such as the 16-50, 50-135
Built in bubble level beside the top LCD
Dual SD Support And/Or SD/CF(Shoot raw on CF, JPEG on SD = Buffer dumps in record time)
Forget the Toshiba Sensor, Partner with Fuji and get an X-Trans up in here!
Illogical process to make the VF 100%, but larger than a FF VF without distortion.
camera, dslr, ii/iis, k-5, k-5 ii, k-5 ii/iis, k-5 iis, k5, pentax k-5
New Firmware For K-01, K-30, K-5, K-5 II, K-5 IIs, K-r Adam Pentax News and Rumors 63 02-18-2013 02:04 PM
K-5 ii vs K-5 iis comparison with higher sharpness in K-5 ii kataria0 Pentax K-5 62 12-22-2012 10:12 PM
Pentax K-5 II and K-5 IIs Now In Stock! Adam Pentax K-5 24 10-25-2012 03:38 PM
Pentax could we get the K-5 II / K-5 IIs in color please? Hegemon Pentax DSLR Discussion 17 10-14-2012 01:59 AM
Facts and rumors regarding the 16.28 Megapixel sensor in K- 5 II and K-5 IIs F-pix Pentax K-5 11 09-28-2012 08:17 AM
All times are GMT -7. The time now is 06:47 AM. | See also: NikonForums.com, part of our network of photo forums!
