04-04-2013, 08:00 PM   #1
Possible to install older version of firmware?
Hi all-
  • Is it possible to replace a Pentax camera's firmware version with an older one, if a newer one is giving unexpected trouble (eg, for certain operations).
  • If possible, is there a firmware archive available? I can only find the latest version on the Pentax site.
I've had a k-5 iis (with the f1.4 fixed, and the 18mm-55m zoom) for about a month, and it still has firmware 1.00 on it. Apart from general camera maintenance, I'd like to see if an upgrade fixes some (real or perceived, not sure yet) focus issues.
Thanks in advance.
-Kurt
04-04-2013, 08:06 PM   #2
Generally speaking the answer is no, you cannot downgrade your firmware. I don't think there are any known issues with the K-5 II apart from the bounce flash thing, which is supposedly being worked on.
Nor is there an official public firmware archive. We do not store firmware files on our site, but many members do keep old FW versions. However, AFAIK Pentax does not delete old downloads. Here is the most recent K-5 IIs firmware:
http://www.pentax.jp/english/support/digital/firmware/K5_2S103.zip
Change the 3 to a 2 or a 1 and you can DL an older version of the zip.
04-05-2013, 09:51 AM   #3
Kobayashi.K's Avatar
Thank you Adam for this info. I tried to download all three versions, but v102 (K5_2S102.zip) is not available anymore.
From a software point of view, upgrades are more complicated than you might think initially. It is possible that a new version also corrects problems introduced by a previous version. I also assume that the last version is a cumulative update otherwise you cannot upgrade from v101 to v103 directly.
camera, dslr, firmware, k-5, k-5 ii, k-5 iis, k5, pentax, pentax k-5, version
to install Firmware Update Software Version 1.03 for K-x DSLR albuda Visitors' Center 1 09-23-2012 04:55 PM
Pentax K7 Firmware Updating to Version 1.11 Vadym Visitors' Center 2 02-07-2012 07:46 PM
Unable to install firmware update v1.02 on K-x califgrll Pentax DSLR Discussion 10 01-15-2011 09:59 AM
K110D Firmware fails to load/install ? ? ? ? ? derek45 Pentax DSLR Discussion 2 09-20-2009 08:22 AM
possible to turn bact to Firmware V1.1? Tayfun Pentax DSLR Discussion 11 02-29-2008 06:23 AM
All times are GMT -7. The time now is 01:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
