04-19-2013, 07:34 AM   #1
K-5 II viewfinder issue
I just purchased a new K-5 II and 18-135 lens. When looking through the viewfinder the image is round, about 75% of the area, and surrounded by black. The info at the bottom is visible and full width as expected. This appears to be something related to the viewfinder as live view looks normal.
Any ideas?
04-19-2013, 07:58 AM   #2
hmmm, maybe your K-5ii is actually the long awaited K-3 ..........
04-19-2013, 08:01 AM   #3
Have you:
- mounted the lens properly
- put on the hood the right way round
- properly adjusted your viewfinder diopter settings?
04-19-2013, 08:05 AM   #4
Welcome to the Pentax Forums! Vignette in the viewfinder, but not in live view? What does it look like when no lens is mounted?
04-19-2013, 08:20 AM   #5
Thanks for the suggestions. My first thought was the hood, so I removed it altogether. Adjusting the diopter has no effect. Pictures come out normally when viewed on my computer, so that leads me to believe it's not a lens issue.
04-19-2013, 08:24 AM   #6
With no lens, it's rectangular.
04-19-2013, 08:29 AM   #7
i83N's Avatar
Try to remove rubber eyepiece from viewfinder
04-19-2013, 09:51 AM   #8
The issue appears to be the focus screen. It's loose and floating around inside the body.
04-19-2013, 10:38 AM   #9
VisualDarkness's Avatar
Loose, how? Can you take pics of it? It should be fitted in a hinge frame that you can lower but when closed it should fit snugly.
04-19-2013, 10:55 AM   #10
My guess is that the frame wasn't hinged properly. In the picture you can see it flopped down. The focus screen itself was completely unattached and just fell out after removing the lens.
04-19-2013, 10:56 AM   #11
Get the camera replaced, the screen will be junk now and who knows if it damaged something else.
04-19-2013, 11:11 AM   #12
kcobain1992's Avatar
Oh God, that's just messed up.
04-19-2013, 05:44 PM   #13
Wow, ugly. Camera must have been thrown around in the box prior to delivery, or something. Get a replacement if you can.
04-19-2013, 06:25 PM   #14
I was able to get in back in place, but it still seems a little off. Sending it back for an exchange.
camera, dslr, ii, k-5, k-5 ii, k-5 iis, k5, pentax k-5, viewfinder
K-5 K-5 II K-5 IIs, e dial issue, Noise Eder Pentax K-5 17 06-03-2014 12:33 AM
New Firmware For K-01, K-30, K-5, K-5 II, K-5 IIs, K-r Adam Pentax News and Rumors 63 02-18-2013 02:04 PM
K-5 II Issue with Photomatix themurth Troubleshooting and Beginner Help 12 01-21-2013 02:14 PM
K-5 ii vs K-5 iis comparison with higher sharpness in K-5 ii kataria0 Pentax K-5 62 12-22-2012 10:12 PM
K 5 cpl and viewfinder issue Extreme G Troubleshooting and Beginner Help 3 08-15-2012 02:54 AM
All times are GMT -7. The time now is 04:19 AM. | See also: NikonForums.com, part of our network of photo forums!
