04-22-2013, 10:29 AM   #1
K-5 with 55-300mm lens
Hi everyone,
My K-5 with Pentax 55-300mm zoom intermittently crashes during autofocus at the wide end...200mm-300mm. the
04-22-2013, 10:45 AM   #2
sterretje's Avatar
Define crashes
I don't use AF-C much and I don't use the DA55-300 much on the K5but under those conditions I have had the camera be totally unresponsive (hangs; with focus point indicator permanently lit in the viewfinder).
I've seen similar reports; maybe a pointer for your problem? I don't know if there is a solution; are you on the latest firmware?
04-22-2013, 12:58 PM   #3
boriscleto's Avatar
I have had the K-5 become unresponsive once, I happened to be using the DA L 55-300 but I don't think that was the cause. In this case I think it was a heat/battery issue. I pulled the battery and it started back up just fine. I took at least another 150 pictures after that with no problems before I was able to charge the battery again.
07-23-2013, 06:31 PM   #4
DA 50-200mm WR and DA 55-300mm, which is better?
07-23-2013, 08:31 PM   #5
boriscleto's Avatar
QuoteOriginally posted by horonggo Quote
Odd thread to resurrect. The WR is better if you need WR or a small lens, but the 300 beats it in every other way.
07-24-2013, 07:15 PM   #6
QuoteOriginally posted by boriscleto Quote
ok, i got it. thanks!
55-300mm, camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
k-5 II and AF on DA 55-300mm Zoom Lens caravan Troubleshooting and Beginner Help 7 04-22-2013 09:01 AM
My K-5 got wet with a 18-55 WR lens! PacoX8 Pentax K-5 45 02-03-2013 11:48 PM
For Sale - Sold: K-5 Kit with 18-55 Lens (Price Reduced) wv76x Sold Items 2 04-21-2012 11:28 PM
For Sale - Sold: Pentax Da-L 55-300mm f/4-5.8 with lens hood and uv filter (Worldwide) suzuki-j Sold Items 4 01-21-2011 11:05 PM
All times are GMT -7. The time now is 11:17 AM. | See also: NikonForums.com, part of our network of photo forums!
