Originally posted by magkelly Unless you're cropping the center detail from a shot taken from 100 feet away and blowing it up to the size of a billboard I think it's actually a bit overkill with how well they can print these days.
A printer prints what is transmitted, nothing more and nothing less, there is no magic printer that takes an image and can magically up the resolution and print a higher-res photo than what it was given. Printer technologies have advanced in the form of print heads and the maximum resolution the printer can print, but again, a printer can not print a higher resolution photo than the file that was sent to it.
In short, a file that is sent to a printer at a given resolution/size is gonna print at the calculated ppi (which is slightly different than dpi and lpi), the higher the ppi the more denser the ink will be (the more pixels will be printed within that square inch) and the more detailed the final output would be, bar none and there is absolutely no cheating this; you can upsample the file but this destroys fine detail.
So no, there is much more use to higher mp cameras than just cropping.
