Lowvoltage - sorry for not getting back to you in time - I guess I missed this thread. But glad to hear you went with the suggestion and it's working well for you
Originally posted by Amante Thanks, just looking at it on the web seems like ACMAXX is a good choice. However my concern is water or moisture getting trapped between the protector and the glass as it is recessed. Now that I am a bit concern as this problem happened to me too quickly after purchasing the camera. So do you think the adhesive around the protector will prevent this?
I actually just returned a couple of weeks ago from being in the field for 5 days, and for literally 80% of the time, we were rained on. I slept outside, so instead of putting my wet cameras in my bag, I just left them outside to survive the night and the elements (we were sleeping in military hooches - sleeping bag under a tarp of your own construction)
I noticed water condence underneath there a little, but that is mostly because I think I dislodged the screen protector a little and caused a small hole in the glue along the edge. Probably from banging and sliding around on my military gear/vests since that's often the uniform in which I shoot (yes, even out of a combat zone
), but I wouldn't worry about that happening to you, especially right away. Otherwise, for the past 6 months, I never had an issue with either screen (rear or top LCD). And if it happens, they aren't expensive, so every 6-12 months you can replace them with new screen protectors. That's why we get them, right? To take all the scratches and abuse so the actual camera screens don't
But I honestly wouldn't worry about dust or moisture getting in there - they seal VERY well. Just make sure you clean the back/top of the camera as best you can so it gets a great adhesion.
Hope this helps, let me know if you need anything else
-Heie
