Hello!
Thought i should try to see if anyone can help me with an old Sitex 28mm f2.8 lens that i bought on e-bay for almost nothing (15$).
The problem is that the lens wonīt focus. No matter how much i turn the focus ring it isnīt even close. Itīs like the focus is just a couple of inches in front of the lens.
I have used several manual lenses before without any problem so my settings should be right, maybe the lens is broken?
The only difference to the other manual lenses iīve used is that this one doesnīt have the "A" mode (can you say that?) on the aperture ring.
