05-20-2013, 06:46 AM   #1
Flash locks camera
When the pop up flash is up the camera locks up and won't fire,sometimes it won't even focus.This is in any mode from P to M
05-20-2013, 06:58 AM   #2
crewl1's Avatar
There is a menu setting that does not allow the camera to trigger if the flash is not ready.
That could be one issue . Normally it should still allow focus to occur though.
Page 82 of the manual.
05-20-2013, 07:02 AM   #3
Will get the book out and check flash settings
Thanks
05-20-2013, 08:33 AM   #4
I think I've seen this as fixed in a firmware update for one of the cameras. Which camera do you have?
05-20-2013, 08:40 AM   #5
On my K-5, it just broke one day. Camera wouldn't work at all with flash popped up. Had to send it in for warranty repair...
05-20-2013, 10:49 AM   #6
Na Horuk's Avatar
Not sure if this is related, but on my K-r the onboard flash is broken and it wont fire. And because the camera wont take a photo if the flash isnt "ready", the camera wont take photos if the flash is up.
Not much you can do other than make sure you charge the battery fully, maybe try a different battery, update firmware, reset to factory defaults.. and if the problem persists, send it in for repairs
camera, dslr, flash, k-5, k-5 ii, k-5 iis, k5, locks, pentax k-5
Pentax 67ii winder locks puggles1973 Pentax Medium Format 7 05-18-2013 02:37 AM
Need to disable in-built flash when using off camera flash Molly Flashes, Lighting, and Studio 18 03-27-2013 04:12 AM
Landscape Amsterdamse Bos locks newmikey Post Your Photos! 4 09-26-2012 07:30 AM
K-30 - control wheel locks up jptreen Pentax K-30 & K-50 10 09-09-2012 09:35 PM
K20 D Locks up flashpete Troubleshooting and Beginner Help 5 10-25-2011 08:12 PM
All times are GMT -7. The time now is 05:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
