05-24-2013, 03:08 PM   #1
Belnan's Avatar
Broken Screw Drive
I am pretty sure the in body autofocus drive on my K-5 has stopped working. All I her is a wizzing but the lenses dont turn, on the plus side all of the sdm/hsm lenses are fine. Does anyone have an idea the cost to repair something like this and the amount of time it takes? I live in Nova Scotia, Canada BTW.
05-24-2013, 03:24 PM   #2
Check that the little screw-thingy on the mount of the body (which is spring-loaded) just isn't stuck and isn't popping out...
05-24-2013, 03:34 PM   #3
Belnan's Avatar
Its not popping out as it should, I tried poking at it carefully but it is still sitting flush with the mount. It dies still seem to have spring but not popping out far enough.
05-24-2013, 03:58 PM   #4
Belnan's Avatar
Fixed It. pheww
Not sure what worked but I put a couple drops of oil down into where the screw drive fits, then I put a lens on and as it was tying to focus I hit the side with my knuckles and it came loose after a minute. crisis averted.
btw thanks vonBaloney
05-24-2013, 05:25 PM   #5
VisualDarkness's Avatar
Maybe some dirt got stuck and the oil made ir loose? Good that it was solved and a little oil shouldn't hurt as long as it was kept in the right spot.
05-25-2013, 11:45 AM   #6
jeffw's Avatar
Use a small drop of rubbing alchohol next time . It does not leave a residue and evaporates . Learned this lesson years ago when someone spilled a rum coke on my LX at a wedding . Camera was fine but winder got all gummed up . Oil might attract dust and make matters worse in the future.
camera, drive, dslr, k-5, k-5 ii, k-5 iis, k5, lenses, pentax k-5
Nikon screw drive body Boker Non-Pentax Cameras: Canon, Nikon, etc. 2 01-06-2013 09:45 PM
Screw Drive Bigma derekkite Pentax SLR Lens Discussion 5 04-10-2012 08:33 AM
Loud Screw Drive userage Pentax SLR Lens Discussion 12 12-17-2011 11:03 PM
Screw driven AF cameras. More high end = better screw drive? Reportage Pentax DSLR Discussion 13 09-01-2011 08:38 AM
Screw-drive auto-focus from the inside Just1MoreDave Pentax SLR Lens Discussion 6 07-28-2009 03:56 PM
All times are GMT -7. The time now is 02:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
