06-13-2013, 11:28 PM   #1
Ofer Hadas's Avatar
Lens or sensor issue
Hi
I've been using the Pentax SLR for a while K100->200->K5. When I travel for work around the world I take the Tamron 18-250 with me as all-in-one lens. Lately I've noticed an issue in the out of focus areas that most of the time has to do with s damaged lens. The thing is that I noticed that also with a Tamron 90mm macro I have especially on water drops where a bright sun light is shinning. Has anyone noticed such effect? Can it be a sensor cleaning issue or both of my lens needs cleaning (attached a cropped area from a picture)
PENTAX K-5  Photo
06-13-2013, 11:54 PM   #2
fs999's Avatar
And if you expose on highlight, does it make the same ?
06-14-2013, 12:32 AM   #3
calsan's Avatar
That's just purple fringing.
We would all use super zooms all the time, if it weren't for the aberrations!
It should be easy to avoid as it happens along the edges of brightly lit subjects. The solution is to stop down the lens (ie smaller aperture.) which is no problem at all in bright light. This is why people tend to talk about super zooms as being good walk around daytime lenses, just f/8 and forget!
The shirt in the picture you showed was overexposed. If exposed correctly, the fringing would be a lot less.
06-14-2013, 12:36 AM   #4
carrrlangas's Avatar
Lens and sensor issue... Better designed lens are so that they diminish purple fringe effect and digital sensors are really sensitive to this kind of phenomenom.
Here you go:
https://en.wikipedia.org/wiki/Purple_fringing
Purple Fringing - Chromatic Aberrations
Itīs fearly easy to remove in post processing though
camera, dslr, issue, k-5, k-5 ii, k-5 iis, k5, lens, pentax k-5, sensor, tamron
Lens or sensor? mvsjes2 Troubleshooting and Beginner Help 8 05-17-2013 06:29 PM
K-5II focusing screen or sensor issue toukan Troubleshooting and Beginner Help 7 12-09-2012 12:14 AM
Mirror issue or Lens? sany Troubleshooting and Beginner Help 22 08-23-2011 07:36 AM
Sensor or lens dust? redspecial Troubleshooting and Beginner Help 30 08-19-2011 04:04 AM
Pentax K-X Shutter or Sensor Issue Due to Moisture Adam B Pentax DSLR Discussion 4 11-10-2010 12:19 PM
All times are GMT -7. The time now is 05:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
