06-24-2013, 09:49 AM   #1
Image Stabilization with manual lenses and adapter
I have not had any success in activating image stabilization on my K5 when using my 645 lenses with a non-Pentax 645 to K adapter that provides no communications link between the lens and the body. I'm guessing the K5 requires communication in order for the IS to operate. If anyone can confirm, thanks in advance.
06-24-2013, 09:51 AM   #2
crewl1's Avatar
I can get stabilization with adapted lenses.
Did you turn on the option to allow lenses with aperture in the menu? Custom menu/ P4/ #27 on my firmware version.
You should get a prompt for focal length when you turn on the camera with unrecognized lenses once you do that.
06-24-2013, 01:10 PM   #3
Stone G.'s Avatar
Same experience here: I can activate or deactivate SR with all MF lenses: K-mount, Takumar, Adaptall P/K as well as P/KA, T-mount lenses, and even with no lens att all mounted.
Just to re-iterate what crew1 has alredy stated above: If you haven't set 'Aperture Ring Permitted' your camera will not ask you to input the focal length when you power up with an adapted/unknown lens mounted and SR cannot be activated.
Furthermore you should also check that 'Shake Reduction' has not been deactivated by accident in the Shooting Menu, page 4 of the K-5.
06-24-2013, 01:16 PM   #4
Na Horuk's Avatar
You need to input the focal length, then you can turn on SR.
But SR is automatically disabled in some cases, like if you have 2 sec timer turned on. So make sure all your other settings allow SR. Then you can press info or whatever and find it.
06-25-2013, 07:33 AM   #5
CDW
Thanks all, the aperture and 2 sec timer issues did the trick.
adapter, camera, dslr, image, image stabilization, k-5, k-5 ii, k-5 iis, k5, lenses, pentax k-5, stabilization
Manual Metering on Pentax DSLRs with Manual and Automatic Lenses Adam Pentax DSLR and Camera Articles 20 01-06-2016 03:38 AM
When I did image stabilization wrong with a Zeiss Distagon 35/2 Chazz5 Pentax K-5 4 06-24-2012 11:55 AM
Lenses with image stabilization Spodeworld Troubleshooting and Beginner Help 16 08-30-2011 07:02 AM
Image Stabilization and Focal Length trevorgrout Troubleshooting and Beginner Help 7 04-20-2010 07:40 AM
Image stabilization and manual SMC A series lenses Rusty Rat Pentax DSLR Discussion 32 01-18-2010 03:45 PM
All times are GMT -7. The time now is 07:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
