06-25-2013, 09:46 AM   #1
tabl10s's Avatar
How Many Of You Know...
your K-5 inside out? How may adjust all the functions without going auto?
06-25-2013, 09:57 AM   #2
panoguy's Avatar
QuoteOriginally posted by tabl10s Quote
I don't know if I know my K-5 "inside out" but I use all the modes on the dial, focus points, HDR and AEB functions, intervalometer, flash modes, drive modes, etc.. Pretty much everything except the Sync port and Mic port. Oh, and I rarely change the metering... lazy I guess!
06-25-2013, 10:07 AM   #3
tabl10s's Avatar
Cool. Since you're the "Go to" man, please answer this. I was messing with the camera this morning and was in flash mode where I had "Slow Speed Synch" enabled. I now can't access that function.
06-25-2013, 11:33 AM   #4
jimr-pdx's Avatar
I access that with the down-button on the 4-way pad (below the OK). That brings up a bunch of flash options.
06-25-2013, 11:38 AM   #5
Shouldn't this be in the K-5 section?
06-25-2013, 11:40 AM   #6
Senior Moderator
Parallax's Avatar
QuoteOriginally posted by lytrytyr Quote
Yes.
Moved from lens forum.
06-25-2013, 11:49 AM   #7
crewl1's Avatar
Slow speed sync is available only in settings where the camera is in control of the shutter speed. If you use TV or TAV or M etc, Slow Speed Synch is disabled.
Is this your situation?
Try switching to AV, SV, P modes.
06-25-2013, 12:16 PM   #8
tabl10s's Avatar
QuoteOriginally posted by crewl1 Quote
Yep,
Thanks.
06-25-2013, 12:26 PM   #9
tabl10s's Avatar
I just discovered something that I hadn't noticed before. I shoot sports using TAv and use Hyper for everything else. It turns out that if you are in Hyper and use the aperture dial, Slow Synch is enabled and disabled when the shutter dial is in use.
Not sure if that's ingenious or meant to confuse.
06-25-2013, 12:48 PM   #10
carrrlangas's Avatar
I just discovered the "Remote continuous drive mode" wi I think it has some surprises for me still.
06-25-2013, 02:18 PM   #11
Banned
Well I have some knowledge over controlling the K-5 (used 5 different body's and made almost 300k images), but there Always thigs you either don't know or forget because off no importance to personal use.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
How many of you are small business owners and how have the past 4 years effected your seacapt General Talk 69 11-03-2012 07:55 AM
Points of sufficiency: do you really know how much is enough? baro-nite Photographic Industry and Professionals 14 09-19-2012 02:14 AM
How many of you guys buy Tamron for their 6 year warranty. Reportage Pentax SLR Lens Discussion 7 01-02-2012 11:43 PM
How many of you... tabl10s Digital Processing, Software, and Printing 12 11-14-2011 03:32 PM
How many of you shoot weddings? hockmasm Photographic Technique 11 07-01-2011 10:05 PM
All times are GMT -7. The time now is 10:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
