Originally posted by krp I tried to make a milky way timelapse last week but my lens fogged up after only 15 minutes
Originally posted by kamayok3 The switch is the ON/OFF for my dew heater cable.
Aha! Very clever. I guess the yellow wire around the lens hood is the heater cable? I wouldn't need one of those out here in the desert. The temperature never drops below the dew point. I'm going out to the mountains, way away from civilization, in two weeks. That will be the perfect opportunity to try something like this.
As you said, I believe my issue with the in-camera intervalometer was stupid settings. If you tell it to shoot in intervals shorter than the actual shutter speed, it will stop taking pictures before it reaches the number you've specified. But then, there was a user complaining of all sorts of intervalometer issues with his K-30 not long ago, but it appears his camera was defective somehow.
I honestly haven't done that much in the two years that I've had Pentax DSLRs. I did a ton right after I discovered the Canon Hack Development Kit (
CHDK). I hacked my old PowerShot to get an intervalometer that worked really well, and it didn't cost anything. That was important in my college days.
I've only put together one video so far. I used most of the footage I took at college. Most of the clips were with the hacked Canon, but one or two were with the K-r. Unfortunately, the video is blocked in some countries (Germany, Sweden, some others) because I used music.
