07-26-2013, 04:36 PM   #1
k-5 auto ficus adjustment
My wife says it is my eyes but I think it is the camera. Anyway if I want to adjust my auto focus what type of object should I shoot to use as the subject for the post adjustment testshots. Something that is complex in texture or something simple? I have three lenses - a DA 18-55mm a DA 50-200mm and a DA* 300mm.
07-26-2013, 04:53 PM   #2
Ideally, you should use one of these tools:
Fixing Front and Back Focus - Introduction - PentaxForums.com
07-26-2013, 04:57 PM   #3
jatrax's Avatar
Hi resolution test target printed on glossy paper. Use a tripod and remote.
AF fine tuning is not a magic bullet. Often the margin of error in a test is larger than the original error. Without a tightly controlled precise test AF fine tuning is just a great way to mess things up even more.
Set up on a tripod, the camera and target must be perfectly aligned both vertcally and horizontally. If the alignment is off at all you can easily makes worse. Take multiple test shots at least 5 after each change.
07-27-2013, 12:01 AM   #4
SpecialK's Avatar
I shot a plain cement walkway that had a crack with some grass in it to focus on. I shot wide open at about 5 ft away, and the zone of focus was easy to see.
adjustment, auto, camera, da, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
auto focus adjustment on k-5 II devouges Troubleshooting and Beginner Help 2 06-27-2013 12:57 PM
Pentax K-5 Newbie question on FA43 AF adjustment bearSeesAll Pentax K-5 4 04-29-2012 10:33 PM
Auto auto focus adjustment Anvh Pentax SLR Lens Discussion 9 04-19-2012 12:49 AM
Auto Focus Adjustment Tom S. Pentax SLR Lens Discussion 2 11-19-2011 03:42 PM
K-5 auto focus fine adjustment tools? Sten Pentax DSLR Discussion 8 03-20-2011 04:28 PM
All times are GMT -7. The time now is 02:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
