08-04-2013, 02:46 AM   #1
Gilzuma's Avatar
K5iis Camera not saving whole picture
Does anyone else have this issue? I have no idea what's happening. Out of the 65 shots that I took this only happened once... but it also seems to have happened on two shots a couple of days ago too. Any ideas?
PENTAX K-5 II s  Photo
08-04-2013, 02:54 AM   #2
manntax's Avatar
card for 99999.99% problem :P Try to reformat, or use another card to see if problem repeats. Also make sure your battery is fresh and fully charged. I think this will be down to the card problem.
Cheers
08-04-2013, 02:55 AM   #3
There is something wrong with the sensor or the circuity associated with pulling the image from the sensor and moving it to the SD card. I guess it could be the card too. Try a new card and if it happens again - take 100 images in a row to test it. Occurs again, then I would send it to the Pentax repair center, along with the SD card containing the partial images.
08-04-2013, 03:47 AM   #4
chrism888's Avatar
Could you have turned the camera off before it had written the data to the card ?
08-04-2013, 04:38 AM   #5
I was about to ask the same question. my k5iis also shows the same problem to a lesser degree, it shows when I download via picassa but is not visible when I view in zoner 14. any thoughts would be appreciated. only had camera a few weeks and everything else seems ok.
08-04-2013, 05:26 AM   #6
QuoteOriginally posted by reynb Quote
Lemme guess: a white and purple band on the right short side?
08-04-2013, 05:43 AM   #7
I heard from few folks about the same problem w/ K-5 IIs ( no aa filter) and also w/K-5 II ( with aa filter). Hopefully it's either some firmware bug ( when Pentax tweaked K-5 firmware to accommodate upgraded AF driver) or some hardware incompatibility of new K-5 models related to SDHC cards. There's an old saying: "if it works, don't fix it" ( it's about K-5's upgrades). Just sayin'.
08-04-2013, 08:05 PM   #8
Gilzuma's Avatar
I've tried reformatting the card... I'm going away for a few days so ill see if that does the trick!
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, shots
K110D sporadically not saving images. ouija Troubleshooting and Beginner Help 3 05-24-2012 11:44 PM
Internal cross processing not saving? mmrempen Pentax K-5 15 04-15-2012 07:24 PM
Pentax Utility 4 Not Saving Correct Color Space jbuck79 Digital Processing, Software, and Printing 2 09-06-2011 02:48 PM
Camera not taking picture. Kiran6790 Troubleshooting and Beginner Help 4 01-26-2011 02:42 AM
Daylight saving time not displayed... Rense Site Suggestions and Help 6 04-13-2009 09:25 AM
All times are GMT -7. The time now is 08:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
