08-10-2013, 06:10 PM   #1
geomez's Avatar
K-5 IIs forgets it's in AF Select mode
I recently started using my K-5 IIs in AF Select mode. I've noticed that sometimes when I turn my camera on with the AF switch on SEL, and I press the D pad to select an AF point, it opens one of the settings assigned to the direction I press as if it is set to Auto AF or center point AF.
In order to select an AF point I have to switch the AF toggle away from SEL and then back again. It is extremely frustrating to have to fiddle around with my camera when I am in the moment ready to shoot.
Does anybody else have this problem?
08-10-2013, 06:13 PM   #2
jatrax's Avatar
Try pressing the OK button first? I think that toggles the screen from SEL to MENU mode.
08-10-2013, 06:28 PM   #3
geomez's Avatar
As I sit here trying to replicate the problem with no success, the OK button does nothing when in AF Select mode. I will have to try that the next time it happens. Even if that solved the problem, my camera should function consistently no matter what is set.
08-10-2013, 06:33 PM   #4
geomez's Avatar
QuoteOriginally posted by geomez Quote
Just realized that holding down the OK button will let me switch from AF Select to function select. But I still don't know why the camera decides on it's own which mode it is in.
08-10-2013, 06:54 PM   #5
jatrax's Avatar
Yes long press I should have said that.
08-10-2013, 07:14 PM   #6
manacho2005's Avatar
You can also assign a "beep" to let you know when it is toggled
camera, dslr, k-5, k-5 ii, k-5 iis, k5, mode, pentax k-5, press, sel, switch
AF Select mode. Am I missing something? Codazzle Pentax K-01 3 12-23-2012 01:04 PM
Pentax could we get the K-5 II / K-5 IIs in color please? Hegemon Pentax DSLR Discussion 17 10-14-2012 01:59 AM
Select Mode AF Area Size Adjustment? Accuracy chaosteo Pentax K-01 3 07-12-2012 08:25 AM
Why does K-5 sound like it's hunting in LiveView mode & only w/ DA* 300mm attached... Epoch Troubleshooting and Beginner Help 2 12-23-2011 04:43 PM
K-5 Select Af point in live view telfish Pentax K-5 & K-5 II 5 10-21-2010 11:38 AM
All times are GMT -7. The time now is 12:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
