Hi,
Thank you all for your answers. It intermittently works like the way it is supposed to.
Infact I took it yesterday for a shootout. I must have taken like 600+ picture. The camera worked like a champ.
I am guessing either the sensor is heated up or something. I am not sure. The focus motor does not work as well too. Just keeps hunting. Specially the mirror! the mirror slaps so slow below that it shakes the camera from inside leading to a blurry image.
I will charge the battery and take it out to take pictures today around the river. (Oh this dampens my entire mood
Ok while typing this I went back to the camera and walked around the house. With the camera. Shooting.
So I noticed it keeps hunting for focus when there are not change in contrast of the subject (Example a while wall - It just did not focus at all).
I noticed the mirror slaps slowly when it is low light. May be the mirror was up due to low light to increase the exposure time. I shoot in Av mode (Aperture priority). I like to keep AUTO -ISO 100-200 range. Aperture as wide open as it allows.
So after 50 more actuation. My actuation count on the camera is now 1000+ Looks like I will run out much before the warranty.
So now I am thinking it is no longer the firmware causing the trouble. May be it is hardware or just a DSLR the way it is supposed to function.
I will wait for today. Shoot 1000 more test shots. Just to check the hardware functionality. Well at the end of the day I will update this thread again.
My best regards and thank you everyone for responding.
Deedee
P.S. I use 94mbps SDHC Sony highspeed 32 GB card. So data transfer is also not the issue
Originally posted by Bruce Clark One thing that will slow down continuous drive mode is a slow shutter speed. If your exposure time is say 1/4 sec then there is now way you can get any more than 4 frames per second. Also check that lens correction correction is not on.
This actually looks like the case, may be I am new to DSLRs. My ISO is set to 100-200 (AUTO ISO) for
Originally posted by manacho2005 Go to your custom section of the menu, tab 3, settings 15 and 16. See if you're set to focus priority or release priority. Release priority will fire 7fps regardless; focus priority will make the camera wait until it confirms focus to fire.
Originally posted by IchabodCrane Have you tried setting the focus switch to Manual Focus? That will give a clue whether the AF system is slowing you down.
Agreed that MF should work, not the case though. It is the mirror issue, it just falls back a little slower.
Originally posted by JohnX Check your rec. mode settings, basically anything that requires the camera to process an image immediately after it's made. Lens correction is an example.
Yes I have them all disabled thank you.
