08-16-2013, 03:02 AM   #16
nanhi's Avatar
QuoteOriginally posted by everydaylife Quote
Did you find the iso80 setting? You have to switch expanded sensitivity to on in custom menu 1. Maybe that would be even better although have you heard the phrase native iso setting. I am not sure my understanding is correct, I am sure someone will correct me if I am wrong, but isn`t that the setting at which image quality will be at its best and as far as I know iso200 is the native iso setting.
Hi everydaylife, your understanding of a sensor's native ISO setting is correct. Just to expand on your info, the sensor's native ISO is the one requiring the least manipulation during processing of the RAW image, as it gives you the highest image quality.
I don't recall where I read this, but when the camera came out I recall a discussion stating the optimal resolution topped out at the ISO 200 setting, with anything below or above that that (80, 400) involving some software trickery. So you may be right.
But here is another hypothesis based on the Default ISO range which is from 100 - 12800. Note: the Expanded Sensitivity is 80 - 51200. This then means the Sensor's Native Sensitivity is ISO 100.
Regards.
camera, dslr, hdr, iso, k-5, k-5 ii, k-5 iis, k5, noise, pentax k-5
Can't select ISO-100 on K-30 brettpr Pentax K-30 & K-50 2 07-04-2013 07:49 PM
K-5: can't select ISO 80 (only 100) fnflying Troubleshooting and Beginner Help 6 03-22-2013 10:31 AM
Is the K10D comparable to K-5 for night photography at iso 100? pcarfan Pentax DSLR Discussion 15 02-21-2012 10:45 PM
missing lowest ISO setting on K-5 / K-7 penties rider Pentax K-5 7 05-08-2011 08:03 AM
Problem with setting ISO on new White K-x whbroker Pentax DSLR Discussion 5 04-15-2010 10:03 AM
All times are GMT -7. The time now is 06:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
